Salta al contenuto principale
Sony Action Cam Mini HDR-AZ1 Memory Card Replacement
  1. Sony Action Cam Mini HDR-AZ1 Memory Card Replacement, Memory Card: passo 1, immagine 1 di 1
    • To access the memory card, pull open the small dust door on the bottom right of the back of the camera.
  2. Sony Action Cam Mini HDR-AZ1 Memory Card Replacement: passo 2, immagine 1 di 3 Sony Action Cam Mini HDR-AZ1 Memory Card Replacement: passo 2, immagine 2 di 3 Sony Action Cam Mini HDR-AZ1 Memory Card Replacement: passo 2, immagine 3 di 3
    • Push inward on the back of the memory card with the tip of your finger until you feel a click and release.
    • Pinch the rear of the memory card that is protruding from the slot and pull outwards until the memory card is removed.
Conclusione
To place a new memory card in, follow these instructions in reverse order.
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 Membro di UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G7
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 548
