Salta al contenuto principale
Sony Action Cam Mini HDR-AZ1 Battery Replacement
  1. Sony Action Cam Mini HDR-AZ1 Battery Replacement, Battery: passo 1, immagine 1 di 3 Sony Action Cam Mini HDR-AZ1 Battery Replacement, Battery: passo 1, immagine 2 di 3 Sony Action Cam Mini HDR-AZ1 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • To access the battery, first make sure the camera is out of the case.
    • Push down on the door lock, located on the rear of the action cam.
    • The door is unlocked if the little yellow square is showing.
    • Pull on the panel door, located on the side opposite the LCD screen, and it should now pop open.
  2. Sony Action Cam Mini HDR-AZ1 Battery Replacement: passo 2, immagine 1 di 3 Sony Action Cam Mini HDR-AZ1 Battery Replacement: passo 2, immagine 2 di 3 Sony Action Cam Mini HDR-AZ1 Battery Replacement: passo 2, immagine 3 di 3
    • Open the side panel outward to reveal the battery.
    • Be sure not to break the small piece of plastic securing the door to the camera.
    • Use the pull tab to pop the battery out of place.
Conclusione
UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015 Membro di UMass Dartmouth, Team 5-7, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G7
3 Membri
10 Guide realizzate
Un commento
Comment changer la battrie du moniteur d'affichage ?
Claude Bouthé - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,122
