Salta al contenuto principale
Sony Action Cam HDR-AS15 O-Ring Replacement
Cosa ti serve
  1. Sony Action Cam HDR-AS15 O-Ring Replacement, Open the Waterproof Case: passo 1, immagine 1 di 1
    • To open the case, push the yellow "Open" tab located at the bottom of the case.
    • Pull out on the yellow tabs as indicated by the circles in the photo to unlock the lid. This may be a little tricky!
    • Then, remove the lid.
  2. Sony Action Cam HDR-AS15 O-Ring Replacement, Pry the O-ring from the Groove: passo 2, immagine 1 di 1
    • Take the plastic opening tool and wedge it between the O-ring and the groove.
    • Then, pry the O-ring until it is out of the groove.
  3. Sony Action Cam HDR-AS15 O-Ring Replacement, Remove the O-ring: passo 3, immagine 1 di 1
    • Now that the O-ring is out of the groove, remove the O-ring from the lid.
Conclusione
USF Tampa, Team 1-2, Sullivan Winter 2015 Membro di USF Tampa, Team 1-2, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G2
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 11
Tutti i Tempi: 876
