Salta al contenuto principale
Sony AZ1VR Lens O Ring Replacement
Cosa ti serve
  1. Sony AZ1VR Lens O Ring Replacement, Lens O Ring: passo 1, immagine 1 di 3 Sony AZ1VR Lens O Ring Replacement, Lens O Ring: passo 1, immagine 2 di 3 Sony AZ1VR Lens O Ring Replacement, Lens O Ring: passo 1, immagine 3 di 3
    • Start by removing the two screws on the bottom, and the screw inside the battery room.
    • Once these are removed, slide the door out, and the small piece of plastic with the door.
  2. Sony AZ1VR Lens O Ring Replacement: passo 2, immagine 1 di 3 Sony AZ1VR Lens O Ring Replacement: passo 2, immagine 2 di 3 Sony AZ1VR Lens O Ring Replacement: passo 2, immagine 3 di 3
    • Now, grab the lens and pull the body out of the plastic, this will reveal the insides of the device.
    • You'll see a screw on the top of the device, towards the front, remove this screw.
    • Next pull the tabs on the bottom and top of the lens, and pull outward, this will remove the lens housing from the body.
  3. Sony AZ1VR Lens O Ring Replacement: passo 3, immagine 1 di 1
    • Next, you'll see a white ring around the lens, slowly remove that ring without causing damage to the device.
    • Now put the new one in its place. Now reassemble the device, it's all set to be used.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 288
