Salta al contenuto principale
Sony α6500 Top Assembly Replacement
Cosa ti serve
  1. Sony α6500 Top Assembly Replacement, Battery: passo 1, immagine 1 di 1
    • Verify the camera is powered off by setting the switch to OFF.
  2. Sony α6500 Top Assembly Replacement: passo 2, immagine 1 di 2 Sony α6500 Top Assembly Replacement: passo 2, immagine 2 di 2
    • Flip the camera upside down.
    • Slide the battery compartment lock to OPEN to unlock it.
  3. Sony α6500 Top Assembly Replacement: passo 3, immagine 1 di 2 Sony α6500 Top Assembly Replacement: passo 3, immagine 2 di 2
    • Push the blue lever aside to release the battery.
  4. Sony α6500 Top Assembly Replacement: passo 4, immagine 1 di 1
    • Remove the released battery from the compartment.
  5. Sony α6500 Top Assembly Replacement, Top Assembly: passo 5, immagine 1 di 2 Sony α6500 Top Assembly Replacement, Top Assembly: passo 5, immagine 2 di 2
    • To access the back of the camera remove the screws attaching the LCD screen hinge to the camera body.
    • Remove four 3 mm JIS 000 screws.
    • Remove one 3 mm JIS 00 screw.
    • After dismounting the screen hinge be careful to avoid tearing the black wire ribbon connecting the screen to the camera body.
  6. Sony α6500 Top Assembly Replacement: passo 6, immagine 1 di 2 Sony α6500 Top Assembly Replacement: passo 6, immagine 2 di 2
    • Grasp the viewfinder eyecup; slide it up and off the viewfinder.
  7. Sony α6500 Top Assembly Replacement: passo 7, immagine 1 di 3 Sony α6500 Top Assembly Replacement: passo 7, immagine 2 di 3 Sony α6500 Top Assembly Replacement: passo 7, immagine 3 di 3
    • Press the flash popup button on the back of the camera.
    • Remove one 5 mm JIS 00 screw from inside the flash compartment.
    • Remove one 4 mm JIS 00 screw.
  8. Sony α6500 Top Assembly Replacement: passo 8, immagine 1 di 3 Sony α6500 Top Assembly Replacement: passo 8, immagine 2 di 3 Sony α6500 Top Assembly Replacement: passo 8, immagine 3 di 3
    • To remove the top of the camera you must remove the back first.
    • Remove the 2.5 mm JIS 00 screw from the side of the camera near the viewfinder.
    • Use the opening tool to pry off the small cover.
    • Remove two 2.5 mm JIS 00 screws from underneath the cover.
    • Remove a 5 mm JIS 00 screw from underneath the cover.
  9. Sony α6500 Top Assembly Replacement: passo 9, immagine 1 di 2 Sony α6500 Top Assembly Replacement: passo 9, immagine 2 di 2
    • Remove three 2.5 mm JIS 0 screws from the back face of the camera.
    • Remove one 4 mm JIS 00 screw from the underside of the lip that overhangs the back of the camera.
  10. Sony α6500 Top Assembly Replacement: passo 10, immagine 1 di 1
    • Remove four 4 mm JIS 0 screws from the bottom of the camera.
  11. Sony α6500 Top Assembly Replacement: passo 11, immagine 1 di 2 Sony α6500 Top Assembly Replacement: passo 11, immagine 2 di 2
    • Flip the battery lock switch to open and open the battery compartment.
    • Remove three 2.5 mm JIS 00 screws from the top of the battery compartment.
    • You may need a longer or thinner screwdriver to reach the screws in the battery compartment.
  12. Sony α6500 Top Assembly Replacement: passo 12, immagine 1 di 2 Sony α6500 Top Assembly Replacement: passo 12, immagine 2 di 2
    • Use the plastic opening tool to begin prying off the back of the camera from the side.
    • Continue to loosen the back until you can open it from the bottom.
  13. Sony α6500 Top Assembly Replacement: passo 13, immagine 1 di 3 Sony α6500 Top Assembly Replacement: passo 13, immagine 2 di 3 Sony α6500 Top Assembly Replacement: passo 13, immagine 3 di 3
    • Open the back of the camera.
    • Use tweezers to remove two ribbon connectors from underneath the back. One connects to the LCD display and the other connects to the right side behind the battery compartment.
    • Ribbon connectors can tear easily. Grasp the plastic ends (not the ribbon) when removing.
  14. Sony α6500 Top Assembly Replacement: passo 14, immagine 1 di 3 Sony α6500 Top Assembly Replacement: passo 14, immagine 2 di 3 Sony α6500 Top Assembly Replacement: passo 14, immagine 3 di 3
    • Use the plastic opening tool to peel down the rubber grip around the handle at least 1 cm.
    • The adhesive holding the rubber grip down should be strong enough to reattach when you are done. If not, you may need an adhesive to reglue it.
    • Remove one 3 mm JIS 000 screw from underneath the rubber grip on the right side.
    • Remove one 4 mm JIS 000 screw from the left side.
  15. Sony α6500 Top Assembly Replacement: passo 15, immagine 1 di 2 Sony α6500 Top Assembly Replacement: passo 15, immagine 2 di 2
    • The last screws holding the top on can be accessed once the back of the camera is removed.
    • Remove one 2.5 mm JIS 00 screw from the top next to the flash mount.
  16. Sony α6500 Top Assembly Replacement: passo 16, immagine 1 di 3 Sony α6500 Top Assembly Replacement: passo 16, immagine 2 di 3 Sony α6500 Top Assembly Replacement: passo 16, immagine 3 di 3
    • Insert a long, thin JIS 00 screwdriver through the two holes and into the battery compartment; remove the two 5mm JIS 00 screws inside it.
  17. Sony α6500 Top Assembly Replacement: passo 17, immagine 1 di 2 Sony α6500 Top Assembly Replacement: passo 17, immagine 2 di 2
    • Use the long, thin, screwdriver to remove one 5 mm JIS 00 screw inside the camera accessible below the dials from the back.
  18. Sony α6500 Top Assembly Replacement: passo 18, immagine 1 di 3 Sony α6500 Top Assembly Replacement: passo 18, immagine 2 di 3 Sony α6500 Top Assembly Replacement: passo 18, immagine 3 di 3
    • Use the plastic opening tool to gently lift up the shutter button assembly.
    • Grasp the front grip from the top and bottom and pull it off. It should come off easily with the shutter button out of the way.
    • The shutter button will still be attached by one ribbon cable once the front grip is removed.
  19. Sony α6500 Top Assembly Replacement: passo 19, immagine 1 di 3 Sony α6500 Top Assembly Replacement: passo 19, immagine 2 di 3 Sony α6500 Top Assembly Replacement: passo 19, immagine 3 di 3
    • Remove one 2.5 mm JIS 00 screw from where the shutter button assembly used to be.
    • Remove one 3 mm JIS 00 screw from the side of the camera.
  20. Sony α6500 Top Assembly Replacement: passo 20, immagine 1 di 2 Sony α6500 Top Assembly Replacement: passo 20, immagine 2 di 2
    • Carefully unplug the two ribbon connectors attaching the top assembly to the rest of the camera.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team S11-G5, Regan Fall 2019 Membro di Cal Poly, Team S11-G5, Regan Fall 2019
CPSU-REGAN-F19S11G5
5 Membri
14 Guide realizzate
Un commento
Do you know where i should buy this? Especially in Indonesia.
Dimasngehe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,106
