Salta al contenuto principale
Sony α6500 Motherboard Replacement
Cosa ti serve
  1. Sony α6500 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Verify the camera is powered off by setting the switch to OFF.
  2. Sony α6500 Motherboard Replacement: passo 2, immagine 1 di 2 Sony α6500 Motherboard Replacement: passo 2, immagine 2 di 2
    • Flip the camera upside down.
    • Slide the battery compartment lock to OPEN to unlock it.
  3. Sony α6500 Motherboard Replacement: passo 3, immagine 1 di 2 Sony α6500 Motherboard Replacement: passo 3, immagine 2 di 2
    • Push the blue lever aside to release the battery.
  4. Sony α6500 Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the released battery from the compartment.
  5. Sony α6500 Motherboard Replacement, Top Assembly: passo 5, immagine 1 di 2 Sony α6500 Motherboard Replacement, Top Assembly: passo 5, immagine 2 di 2
    • To access the back of the camera remove the screws attaching the LCD screen hinge to the camera body.
    • Remove four 3 mm JIS 000 screws.
    • Remove one 3 mm JIS 00 screw.
    • After dismounting the screen hinge be careful to avoid tearing the black wire ribbon connecting the screen to the camera body.
  6. Sony α6500 Motherboard Replacement: passo 6, immagine 1 di 2 Sony α6500 Motherboard Replacement: passo 6, immagine 2 di 2
    • Grasp the viewfinder eyecup; slide it up and off the viewfinder.
  7. Sony α6500 Motherboard Replacement: passo 7, immagine 1 di 3 Sony α6500 Motherboard Replacement: passo 7, immagine 2 di 3 Sony α6500 Motherboard Replacement: passo 7, immagine 3 di 3
    • Press the flash popup button on the back of the camera.
    • Remove one 5 mm JIS 00 screw from inside the flash compartment.
    • Remove one 4 mm JIS 00 screw.
  8. Sony α6500 Motherboard Replacement: passo 8, immagine 1 di 3 Sony α6500 Motherboard Replacement: passo 8, immagine 2 di 3 Sony α6500 Motherboard Replacement: passo 8, immagine 3 di 3
    • To remove the top of the camera you must remove the back first.
    • Remove the 2.5 mm JIS 00 screw from the side of the camera near the viewfinder.
    • Use the opening tool to pry off the small cover.
    • Remove two 2.5 mm JIS 00 screws from underneath the cover.
    • Remove a 5 mm JIS 00 screw from underneath the cover.
  9. Sony α6500 Motherboard Replacement: passo 9, immagine 1 di 2 Sony α6500 Motherboard Replacement: passo 9, immagine 2 di 2
    • Remove three 2.5 mm JIS 0 screws from the back face of the camera.
    • Remove one 4 mm JIS 00 screw from the underside of the lip that overhangs the back of the camera.
  10. Sony α6500 Motherboard Replacement: passo 10, immagine 1 di 1
    • Remove four 4 mm JIS 0 screws from the bottom of the camera.
  11. Sony α6500 Motherboard Replacement: passo 11, immagine 1 di 2 Sony α6500 Motherboard Replacement: passo 11, immagine 2 di 2
    • Flip the battery lock switch to open and open the battery compartment.
    • Remove three 2.5 mm JIS 00 screws from the top of the battery compartment.
    • You may need a longer or thinner screwdriver to reach the screws in the battery compartment.
  12. Sony α6500 Motherboard Replacement: passo 12, immagine 1 di 2 Sony α6500 Motherboard Replacement: passo 12, immagine 2 di 2
    • Use the plastic opening tool to begin prying off the back of the camera from the side.
    • Continue to loosen the back until you can open it from the bottom.
  13. Sony α6500 Motherboard Replacement: passo 13, immagine 1 di 3 Sony α6500 Motherboard Replacement: passo 13, immagine 2 di 3 Sony α6500 Motherboard Replacement: passo 13, immagine 3 di 3
    • Open the back of the camera.
    • Use tweezers to remove two ribbon connectors from underneath the back. One connects to the LCD display and the other connects to the right side behind the battery compartment.
    • Ribbon connectors can tear easily. Grasp the plastic ends (not the ribbon) when removing.
  14. Sony α6500 Motherboard Replacement: passo 14, immagine 1 di 3 Sony α6500 Motherboard Replacement: passo 14, immagine 2 di 3 Sony α6500 Motherboard Replacement: passo 14, immagine 3 di 3
    • Use the plastic opening tool to peel down the rubber grip around the handle at least 1 cm.
    • The adhesive holding the rubber grip down should be strong enough to reattach when you are done. If not, you may need an adhesive to reglue it.
    • Remove one 3 mm JIS 000 screw from underneath the rubber grip on the right side.
    • Remove one 4 mm JIS 000 screw from the left side.
  15. Sony α6500 Motherboard Replacement: passo 15, immagine 1 di 2 Sony α6500 Motherboard Replacement: passo 15, immagine 2 di 2
    • The last screws holding the top on can be accessed once the back of the camera is removed.
    • Remove one 2.5 mm JIS 00 screw from the top next to the flash mount.
  16. Sony α6500 Motherboard Replacement: passo 16, immagine 1 di 3 Sony α6500 Motherboard Replacement: passo 16, immagine 2 di 3 Sony α6500 Motherboard Replacement: passo 16, immagine 3 di 3
    • Insert a long, thin JIS 00 screwdriver through the two holes and into the battery compartment; remove the two 5mm JIS 00 screws inside it.
  17. Sony α6500 Motherboard Replacement: passo 17, immagine 1 di 2 Sony α6500 Motherboard Replacement: passo 17, immagine 2 di 2
    • Use the long, thin, screwdriver to remove one 5 mm JIS 00 screw inside the camera accessible below the dials from the back.
  18. Sony α6500 Motherboard Replacement: passo 18, immagine 1 di 3 Sony α6500 Motherboard Replacement: passo 18, immagine 2 di 3 Sony α6500 Motherboard Replacement: passo 18, immagine 3 di 3
    • Use the plastic opening tool to gently lift up the shutter button assembly.
    • Grasp the front grip from the top and bottom and pull it off. It should come off easily with the shutter button out of the way.
    • The shutter button will still be attached by one ribbon cable once the front grip is removed.
  19. Sony α6500 Motherboard Replacement: passo 19, immagine 1 di 3 Sony α6500 Motherboard Replacement: passo 19, immagine 2 di 3 Sony α6500 Motherboard Replacement: passo 19, immagine 3 di 3
    • Remove one 2.5 mm JIS 00 screw from where the shutter button assembly used to be.
    • Remove one 3 mm JIS 00 screw from the side of the camera.
  20. Sony α6500 Motherboard Replacement: passo 20, immagine 1 di 2 Sony α6500 Motherboard Replacement: passo 20, immagine 2 di 2
    • Carefully unplug the two ribbon connectors attaching the top assembly to the rest of the camera.
  21. Sony α6500 Motherboard Replacement, Viewfinder Glass: passo 21, immagine 1 di 3 Sony α6500 Motherboard Replacement, Viewfinder Glass: passo 21, immagine 2 di 3 Sony α6500 Motherboard Replacement, Viewfinder Glass: passo 21, immagine 3 di 3
    • From the top of the camera remove one 4mm JIS 00 screw.
    • Remove one 5mm JIS 00 screw and the plastic bushing around it.
    • Remove the viewfinder's protective cover.
  22. Sony α6500 Motherboard Replacement: passo 22, immagine 1 di 2 Sony α6500 Motherboard Replacement: passo 22, immagine 2 di 2
    • Use the spudger to pry the light sensor off the side of the viewfinder.
    • When prying off the sensor, bend it out from the bottom.
    • Remove one 2.5mm JIS 000 screw on the side of the viewfinder to release it.
  23. Sony α6500 Motherboard Replacement: passo 23, immagine 1 di 2 Sony α6500 Motherboard Replacement: passo 23, immagine 2 di 2
    • Lift the viewfinder out and flip up the tab to release the wire ribbon where it is connected to the motherboard.
  24. Sony α6500 Motherboard Replacement, Motherboard: passo 24, immagine 1 di 3 Sony α6500 Motherboard Replacement, Motherboard: passo 24, immagine 2 di 3 Sony α6500 Motherboard Replacement, Motherboard: passo 24, immagine 3 di 3
    • Remove two 2.5mm JIS 00 screws from the left side and bottom of the copper shielding.
    • Remove two 2mm JIS 000 screws from the right side of the copper shielding.
    • Pull the entire copper shielding piece off.
    • When replacing the shielding, make sure to position the wire ribbon slot under the tabs designed to hold it down.
  25. Sony α6500 Motherboard Replacement: passo 25, immagine 1 di 2 Sony α6500 Motherboard Replacement: passo 25, immagine 2 di 2
    • You have now accessed the motherboard. The next step is to remove all the wire ribbons attached to it.
    • Remove one 4mm JIS 00 screw holding down a plastic spacer on the bottom left of the motherboard.
  26. Sony α6500 Motherboard Replacement: passo 26, immagine 1 di 3 Sony α6500 Motherboard Replacement: passo 26, immagine 2 di 3 Sony α6500 Motherboard Replacement: passo 26, immagine 3 di 3
    • Use tweezers to carefully pull out the first wire ribbon on the left side of the motherboard.
    • Use the spudger to flip up the tab locking in the wire ribbons at the bottom of the motherboard, then pull them out with tweezers.
  27. Sony α6500 Motherboard Replacement: passo 27, immagine 1 di 3 Sony α6500 Motherboard Replacement: passo 27, immagine 2 di 3 Sony α6500 Motherboard Replacement: passo 27, immagine 3 di 3
    • Carefully use tweezers to remove four wire ribbons on the right side of the motherboard.
    • Remove the last two wire ribbons on the top of the motherboard by flipping up the locking tab and pulling them out.
    • Pull the blue coaxial cable up off the board.
  28. Sony α6500 Motherboard Replacement: passo 28, immagine 1 di 3 Sony α6500 Motherboard Replacement: passo 28, immagine 2 di 3 Sony α6500 Motherboard Replacement: passo 28, immagine 3 di 3
    • Remove one 4mm JIS 00 screw from the upper right of the motherboard and another from the far left.
    • Remove the plastic housing for the power and HDMI ports.
  29. Sony α6500 Motherboard Replacement: passo 29, immagine 1 di 3 Sony α6500 Motherboard Replacement: passo 29, immagine 2 di 3 Sony α6500 Motherboard Replacement: passo 29, immagine 3 di 3
    • The flash capacitors connected to the yellow wire harness have dangerous amounts of stored charge. You must safely discharge them before continuing. Use a Capacitor Discharging Tool to do so.
    • Grasp the motherboard from the sides and lift it up. It is still connected by two wires on the bottom right side.
    • Pull the wire ribbon on the underside off with tweezers.
    • After you have discharged the capacitor, pull the yellow wire harness out using tweezers.
  30. Sony α6500 Motherboard Replacement: passo 30, immagine 1 di 1
    • Disconnect the wire ribbon connecting the power port to the board.
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team S11-G5, Regan Fall 2019 Membro di Cal Poly, Team S11-G5, Regan Fall 2019
CPSU-REGAN-F19S11G5
5 Membri
14 Guide realizzate
Un commento
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 58
Tutti i Tempi: 3,652
