Salta al contenuto principale
Introduzione
In order to interface with the camera and access its functions, it is important to have a working LCD screen. If your LCD screen has problems such as distortion and flickering, it may be damaged and in need of replacement. This guide will walk you through disassembling the camera and removing the LCD screen; avoid tearing the flat ribbon cables exposed in the process. When removing the screen from the plastic frame, you will break the adhesive attaching it. If desired, you may reglue the replacement screen to the frame with any super glue or epoxy. This guide requires JIS 00 and 000 screwdrivers, opening tools, a spudger, and tweezers.
  1. Sony α6500 LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Verify the camera is powered off by setting the switch to OFF.
  2. Sony α6500 LCD Screen Replacement: passo 2, immagine 1 di 2 Sony α6500 LCD Screen Replacement: passo 2, immagine 2 di 2
    • Flip the camera upside down.
    • Slide the battery compartment lock to OPEN to unlock it.
  3. Sony α6500 LCD Screen Replacement: passo 3, immagine 1 di 2 Sony α6500 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Push the blue lever aside to release the battery.
  4. Sony α6500 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Remove the released battery from the compartment.
  5. Sony α6500 LCD Screen Replacement, LCD Screen: passo 5, immagine 1 di 3 Sony α6500 LCD Screen Replacement, LCD Screen: passo 5, immagine 2 di 3 Sony α6500 LCD Screen Replacement, LCD Screen: passo 5, immagine 3 di 3
    • To access the LCD assembly we need to remove the screws attaching its hinge to the camera body.
    • Remove four 3mm JIS 000 screws.
    • Remove one 3mm JIS 00 screw.
    • After dismounting the screen hinge be careful to not tear the black wire ribbon connecting the screen to the camera body.
  6. Sony α6500 LCD Screen Replacement: passo 6, immagine 1 di 2 Sony α6500 LCD Screen Replacement: passo 6, immagine 2 di 2
    • Remove the screen hinge from the camera.
    • Be careful to not tear the black flat cable connecting the lcd screen to the main body of the camera. This particular camera's cable has been cut for demonstration purposes.
  7. Sony α6500 LCD Screen Replacement: passo 7, immagine 1 di 1
    • Flip the LCD screen up.
    • Remove two 2mm JIS 000 screws on the bottom edge.
  8. Sony α6500 LCD Screen Replacement: passo 8, immagine 1 di 2 Sony α6500 LCD Screen Replacement: passo 8, immagine 2 di 2
    • Flip the LCD screen down to access the back side.
    • Remove two 2mm JIS 000 screws to release the back panel of the screen.
  9. Sony α6500 LCD Screen Replacement: passo 9, immagine 1 di 2 Sony α6500 LCD Screen Replacement: passo 9, immagine 2 di 2
    • Use the opening tool to pry open the back panel.
    • Remove the black plastic spacer laying on top of the circuit board.
  10. Sony α6500 LCD Screen Replacement: passo 10, immagine 1 di 2 Sony α6500 LCD Screen Replacement: passo 10, immagine 2 di 2
    • Carefully unplug the three wire ribbons from the circuit board with tweezers.
    • Likely you will need to wiggle the ribbons for a while before they come loose.
    • The ribbons can rip very easily, grasp the black plastic with the tweezers, on the two top ribbons, not the orange wires.
  11. Sony α6500 LCD Screen Replacement: passo 11, immagine 1 di 3 Sony α6500 LCD Screen Replacement: passo 11, immagine 2 di 3 Sony α6500 LCD Screen Replacement: passo 11, immagine 3 di 3
    • Slide the spudger around all sides of the screen's plastic frame, gently breaking the adhesive.
    • Remove the screen from the camera by prying it out.
Conclusione
Cal Poly, Team S11-G5, Regan Fall 2019 Membro di Cal Poly, Team S11-G5, Regan Fall 2019
CPSU-REGAN-F19S11G5
5 Membri
14 Guide realizzate
2 Commenti
Hello, do you have an updated link with a currently available lcd screen replacement part?
JRS - Joe’s Random Stuff - Replica
Can I use an a6500 screen to replace an a6600 screen? Are they interchangeable?
Connor Snyder - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 51
Tutti i Tempi: 1,470
