Salta al contenuto principale
Sony α6500 Flash Replacement
Cosa ti serve
  1. Sony α6500 Flash Replacement, Battery: passo 1, immagine 1 di 1
    • Verify the camera is powered off by setting the switch to OFF.
  2. Sony α6500 Flash Replacement: passo 2, immagine 1 di 2 Sony α6500 Flash Replacement: passo 2, immagine 2 di 2
    • Flip the camera upside down.
    • Slide the battery compartment lock to OPEN to unlock it.
  3. Sony α6500 Flash Replacement: passo 3, immagine 1 di 2 Sony α6500 Flash Replacement: passo 3, immagine 2 di 2
    • Push the blue lever aside to release the battery.
  4. Sony α6500 Flash Replacement: passo 4, immagine 1 di 1
    • Remove the released battery from the compartment.
  5. Sony α6500 Flash Replacement, Top Assembly: passo 5, immagine 1 di 2 Sony α6500 Flash Replacement, Top Assembly: passo 5, immagine 2 di 2
    • To access the back of the camera remove the screws attaching the LCD screen hinge to the camera body.
    • Remove four 3 mm JIS 000 screws.
    • Remove one 3 mm JIS 00 screw.
    • After dismounting the screen hinge be careful to avoid tearing the black wire ribbon connecting the screen to the camera body.
  6. Sony α6500 Flash Replacement: passo 6, immagine 1 di 2 Sony α6500 Flash Replacement: passo 6, immagine 2 di 2
    • Grasp the viewfinder eyecup; slide it up and off the viewfinder.
  7. Sony α6500 Flash Replacement: passo 7, immagine 1 di 3 Sony α6500 Flash Replacement: passo 7, immagine 2 di 3 Sony α6500 Flash Replacement: passo 7, immagine 3 di 3
    • Press the flash popup button on the back of the camera.
    • Remove one 5 mm JIS 00 screw from inside the flash compartment.
    • Remove one 4 mm JIS 00 screw.
  8. Sony α6500 Flash Replacement: passo 8, immagine 1 di 3 Sony α6500 Flash Replacement: passo 8, immagine 2 di 3 Sony α6500 Flash Replacement: passo 8, immagine 3 di 3
    • To remove the top of the camera you must remove the back first.
    • Remove the 2.5 mm JIS 00 screw from the side of the camera near the viewfinder.
    • Use the opening tool to pry off the small cover.
    • Remove two 2.5 mm JIS 00 screws from underneath the cover.
    • Remove a 5 mm JIS 00 screw from underneath the cover.
  9. Sony α6500 Flash Replacement: passo 9, immagine 1 di 2 Sony α6500 Flash Replacement: passo 9, immagine 2 di 2
    • Remove three 2.5 mm JIS 0 screws from the back face of the camera.
    • Remove one 4 mm JIS 00 screw from the underside of the lip that overhangs the back of the camera.
  10. Sony α6500 Flash Replacement: passo 10, immagine 1 di 1
    • Remove four 4 mm JIS 0 screws from the bottom of the camera.
  11. Sony α6500 Flash Replacement: passo 11, immagine 1 di 2 Sony α6500 Flash Replacement: passo 11, immagine 2 di 2
    • Flip the battery lock switch to open and open the battery compartment.
    • Remove three 2.5 mm JIS 00 screws from the top of the battery compartment.
    • You may need a longer or thinner screwdriver to reach the screws in the battery compartment.
  12. Sony α6500 Flash Replacement: passo 12, immagine 1 di 2 Sony α6500 Flash Replacement: passo 12, immagine 2 di 2
    • Use the plastic opening tool to begin prying off the back of the camera from the side.
    • Continue to loosen the back until you can open it from the bottom.
  13. Sony α6500 Flash Replacement: passo 13, immagine 1 di 3 Sony α6500 Flash Replacement: passo 13, immagine 2 di 3 Sony α6500 Flash Replacement: passo 13, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Open the back of the camera.
    • Use tweezers to remove two ribbon connectors from underneath the back. One connects to the LCD display and the other connects to the right side behind the battery compartment.
    • Ribbon connectors can tear easily. Grasp the plastic ends (not the ribbon) when removing.
  14. Sony α6500 Flash Replacement: passo 14, immagine 1 di 3 Sony α6500 Flash Replacement: passo 14, immagine 2 di 3 Sony α6500 Flash Replacement: passo 14, immagine 3 di 3
    • Use the plastic opening tool to peel down the rubber grip around the handle at least 1 cm.
    • The adhesive holding the rubber grip down should be strong enough to reattach when you are done. If not, you may need an adhesive to reglue it.
    • Remove one 3 mm JIS 000 screw from underneath the rubber grip on the right side.
    • Remove one 4 mm JIS 000 screw from the left side.
  15. Sony α6500 Flash Replacement: passo 15, immagine 1 di 2 Sony α6500 Flash Replacement: passo 15, immagine 2 di 2
    • The last screws holding the top on can be accessed once the back of the camera is removed.
    • Remove one 2.5 mm JIS 00 screw from the top next to the flash mount.
  16. Sony α6500 Flash Replacement: passo 16, immagine 1 di 3 Sony α6500 Flash Replacement: passo 16, immagine 2 di 3 Sony α6500 Flash Replacement: passo 16, immagine 3 di 3
    • Insert a long, thin JIS 00 screwdriver through the two holes and into the battery compartment; remove the two 5mm JIS 00 screws inside it.
  17. Sony α6500 Flash Replacement: passo 17, immagine 1 di 2 Sony α6500 Flash Replacement: passo 17, immagine 2 di 2
    • Use the long, thin, screwdriver to remove one 5 mm JIS 00 screw inside the camera accessible below the dials from the back.
  18. Sony α6500 Flash Replacement: passo 18, immagine 1 di 3 Sony α6500 Flash Replacement: passo 18, immagine 2 di 3 Sony α6500 Flash Replacement: passo 18, immagine 3 di 3
    • Use the plastic opening tool to gently lift up the shutter button assembly.
    • Grasp the front grip from the top and bottom and pull it off. It should come off easily with the shutter button out of the way.
    • The shutter button will still be attached by one ribbon cable once the front grip is removed.
  19. Sony α6500 Flash Replacement: passo 19, immagine 1 di 3 Sony α6500 Flash Replacement: passo 19, immagine 2 di 3 Sony α6500 Flash Replacement: passo 19, immagine 3 di 3
    • Remove one 2.5 mm JIS 00 screw from where the shutter button assembly used to be.
    • Remove one 3 mm JIS 00 screw from the side of the camera.
  20. Sony α6500 Flash Replacement: passo 20, immagine 1 di 2 Sony α6500 Flash Replacement: passo 20, immagine 2 di 2
    • Carefully unplug the two ribbon connectors attaching the top assembly to the rest of the camera.
  21. Sony α6500 Flash Replacement, Flash: passo 21, immagine 1 di 2 Sony α6500 Flash Replacement, Flash: passo 21, immagine 2 di 2
    • Remove one 3mm JIS 00 screw from each side of the flash.
    • Remove the casing of the flash.
  22. Sony α6500 Flash Replacement: passo 22, immagine 1 di 2 Sony α6500 Flash Replacement: passo 22, immagine 2 di 2
    • Place the top of the camera top down.
    • Remove one 2.5mm JIS 00 screw.
  23. Sony α6500 Flash Replacement: passo 23, immagine 1 di 1
    • Remove the flash from the top of the camera.
  24. Sony α6500 Flash Replacement: passo 24, immagine 1 di 3 Sony α6500 Flash Replacement: passo 24, immagine 2 di 3 Sony α6500 Flash Replacement: passo 24, immagine 3 di 3
    • Pry off the plastic cover over the wire ribbon on the flash pop-up.
    • Use the spudger to loosen the adhesive holding the wire ribbon down underneath the flash mount.
    • Pull the flash bulb and wire ribbon out to replace.
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team S11-G5, Regan Fall 2019 Membro di Cal Poly, Team S11-G5, Regan Fall 2019
CPSU-REGAN-F19S11G5
5 Membri
14 Guide realizzate
4 Commenti
I would like to know how do I take out the top cover only in order to access the on/off switch, it seems impossible to find this, after a long search I am loosing hope hahaha.
artur_jeronimo - Replica
Hi. To get the button removed you actually will need to follow the steps on this guide through step 18. Unfortunately the process is more complicated than it needs to be but in order to remove the front grip and access the button you will need to follow all the steps before. Look at steps 17 and 18 in detail to see the exact process of removing the button housing.
Micah Fitzgerald -
I would just like to let you know that I successfully replaced the flash unit. Thank you very much for this guide. I only had trouble finding the plug for the ribbon cable from the flash unit to reconnect it. In your photo, the ribbon cable is already disconnected, and I could not remember where it was plugged in. But finally, I found it and everything is working.
Christa Rohrbach - Replica
On step 24 is the flash bulb and wire ribbon all one piece? Is it one part as far as replacement? I think that is what my camera needs. Do you have a recommendation on where this part can be ordered from? Appreciate the help!
Thanks,
Amy
ajones - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 808
