Introduzione
LCD sta per "liquid crystal display" (schermo a cristalli liquidi), ed è utilizzato per i display in diversi dispositivi. Gli schermi LCD sono più sottili rispetto alle tecnologie più datate, offrendo una migliore qualità delle immagini. Questa guida ti mostrerà con successo come sostituire lo schermo LCD della tua fotocamera Sony a6000.
Cosa ti serve
Rimuovi le due viti Phillips #00 da 1,75 mm posizionate sul margine inferiore dello schermo LCD.
Per rimontare il tuo dispositivo, segui queste istruzioni in ordine inverso.
Un ringraziamento speciale a questi traduttori:
100%
ToToMalux ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
2 Commenti
Saw a bran new a6000 screen on eBay. So, I thought it would be easy to replace the scratched screen from my a6000. WOW was I wrong!
First I would say that step 2 is very hard to accomplish without stripping the screw. You need to pry the screen to get to an angle where it's doable. On my first attempt I striped the screw. I tried it on a second a6000 and successfully could remove the screw.
As it wasn't evident to me at first, I think it's important to specify that on step 7 you need to lift carefully the little black flap on the zero insertion force cable connector to unlock it. It's weak and I feel like it would be very prone to breaking.
What is NOT showed on this guide is what comes AFTER step 8! The screen is actually in a plastic frame That does not ship with the replacement screen and this frame is glued! So unless you have plastic glue and are able to unglue it first, you should NOT attempt this repair.
Consequently, I reassembled everything and have resigned myself to living with the scratchs.
