Salta al contenuto principale
Sonos Playbase Optical Audio Port Replacement
Cosa ti serve
  1. Sonos Playbase Optical Audio Port Replacement, Bottom Panel: passo 1, immagine 1 di 3 Sonos Playbase Optical Audio Port Replacement, Bottom Panel: passo 1, immagine 2 di 3 Sonos Playbase Optical Audio Port Replacement, Bottom Panel: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Pro Tech Toolkit
    $74.95
    Compra
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
  2. Sonos Playbase Optical Audio Port Replacement: passo 2, immagine 1 di 2 Sonos Playbase Optical Audio Port Replacement: passo 2, immagine 2 di 2
    Pro Tech Toolkit
    $74.95
    Compra
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
  3. Sonos Playbase Optical Audio Port Replacement: passo 3, immagine 1 di 2 Sonos Playbase Optical Audio Port Replacement: passo 3, immagine 2 di 2
    Pro Tech Toolkit
    $74.95
    Compra
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
  4. Sonos Playbase Optical Audio Port Replacement, Optical Audio Port: passo 4, immagine 1 di 2 Sonos Playbase Optical Audio Port Replacement, Optical Audio Port: passo 4, immagine 2 di 2
    • Unplug the optical audio port from the main circuit board by pinching the white clip and pulling upward.
  5. Sonos Playbase Optical Audio Port Replacement: passo 5, immagine 1 di 2 Sonos Playbase Optical Audio Port Replacement: passo 5, immagine 2 di 2
    • Remove the three 38mm T-55 screws preventing you from removing the Optical Audio Port screws by turning them counterclockwise.
  6. Sonos Playbase Optical Audio Port Replacement: passo 6, immagine 1 di 2 Sonos Playbase Optical Audio Port Replacement: passo 6, immagine 2 di 2
    Pro Tech Toolkit
    $74.95
    Compra
    • Remove the two 18mm T-10 screws holding the Ethernet Port in place by turning them counterclockwise.
  7. Sonos Playbase Optical Audio Port Replacement: passo 7, immagine 1 di 2 Sonos Playbase Optical Audio Port Replacement: passo 7, immagine 2 di 2
    • Remove the Optical Audio Port from the housing by pinching the sides and pulling outward.
Conclusione
Cal Poly, Team S17-G2, White Fall 2018 Membro di Cal Poly, Team S17-G2, White Fall 2018
CPSU-WHITE-F18S17G2
4 Membri
8 Guide realizzate
Un commento
Thank you for this guide, but any idea where to purchase a replacement optical audio port from?
donovanclarkson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,317
