Salta al contenuto principale
Sonos Play 5 Antenna Replacement
Cosa ti serve
  1. Sonos Play 5 Antenna Replacement, Front Panel Assembly: passo 1, immagine 1 di 1
    • Disconnect any power to the speaker and wait a few minutes for the capacitors to fully discharge.
    • Flip the speaker upside down.
    • There may be a rubber foot covering the bottom screws (not included in picture). Remove this by pulling up from one of the corners using a spudger.
  2. Sonos Play 5 Antenna Replacement: passo 2, immagine 1 di 2 Sonos Play 5 Antenna Replacement: passo 2, immagine 2 di 2
    • Remove eight 10mm Phillips #2 screws
    • Remove the bottom panel by pulling upwards.
    • Be very gentle with the ends of the three antennas. They are very fragile.
  3. Sonos Play 5 Antenna Replacement: passo 3, immagine 1 di 3 Sonos Play 5 Antenna Replacement: passo 3, immagine 2 di 3 Sonos Play 5 Antenna Replacement: passo 3, immagine 3 di 3
    • Flip the device so that the grille is facing up.
    • Locate the line on the right side of the speaker where the grill and the plastic meet, and place your plastic opening tool in the gap.
    • Run the spudger along the gap, loosening the grille from the plastic. Repeat this process on the left side as well.
    • Gently pull up on the grille, removing it from the front panel.
  4. Sonos Play 5 Antenna Replacement: passo 4, immagine 1 di 1
    • Remove the six 8mm Phillips #2 screws.
    • Remove the two 10mm Phillips #2 screws.
  5. Sonos Play 5 Antenna Replacement: passo 5, immagine 1 di 2 Sonos Play 5 Antenna Replacement: passo 5, immagine 2 di 2
    • Locate the line on the right side where the front panel and back panel meet. Place a plastic opening tool in the gap, and run it along the gap. Repeat this on the left side.
    • Use the opening tool to lift the front plate. If a plastic tool is not providing enough leverage, use a metal opening tool.
    • Gently pull up on the face plate to ensure it has been detached from the enclosure.
    • When pulling on the face plate be cautious because it is still connected by wires on the back of the plate.
  6. Sonos Play 5 Antenna Replacement: passo 6, immagine 1 di 3 Sonos Play 5 Antenna Replacement: passo 6, immagine 2 di 3 Sonos Play 5 Antenna Replacement: passo 6, immagine 3 di 3
    • Lift up the front panel, forming a 90 degree angle with the back panel. Locate the locate ten pin connector shown. This is the wire that connects the front panel to back panel.
    • Press down on the small tab located on the connector. With the tab firmly pressed down, pull the connector out from its socket.
    • The faceplate assembly is now fully detached from the rest of the speaker.
  7. Sonos Play 5 Antenna Replacement, Motherboard: passo 7, immagine 1 di 3 Sonos Play 5 Antenna Replacement, Motherboard: passo 7, immagine 2 di 3 Sonos Play 5 Antenna Replacement, Motherboard: passo 7, immagine 3 di 3
    • Remove the ten pin connector.
  8. Sonos Play 5 Antenna Replacement: passo 8, immagine 1 di 1
    • Flip the device over on its front side.
  9. Sonos Play 5 Antenna Replacement: passo 9, immagine 1 di 1
    • Remove six 5mm Phillips #0 screws.
    • Remove two 7mm Phillips #2 screws.
  10. Sonos Play 5 Antenna Replacement: passo 10, immagine 1 di 1
    • Flip the device on its back.
  11. Sonos Play 5 Antenna Replacement: passo 11, immagine 1 di 3 Sonos Play 5 Antenna Replacement: passo 11, immagine 2 di 3 Sonos Play 5 Antenna Replacement: passo 11, immagine 3 di 3
    • Remove the grey and red antenna connectors by lifting them away from the board.
    • Pull cords away from the board.
  12. Sonos Play 5 Antenna Replacement: passo 12, immagine 1 di 2 Sonos Play 5 Antenna Replacement: passo 12, immagine 2 di 2
    • Remove the yellow antenna connector by lifting it away from the board.
    • Pull cord away from the board.
  13. Sonos Play 5 Antenna Replacement: passo 13, immagine 1 di 3 Sonos Play 5 Antenna Replacement: passo 13, immagine 2 di 3 Sonos Play 5 Antenna Replacement: passo 13, immagine 3 di 3
    • Remove circuit board by lifting it straight away from the rear plate.
  14. Sonos Play 5 Antenna Replacement, Antenna: passo 14, immagine 1 di 1
    • Flip device so that the bottom is facing upwards.
    • Identify the 3 antennas to be replaced.
  15. Sonos Play 5 Antenna Replacement: passo 15, immagine 1 di 3 Sonos Play 5 Antenna Replacement: passo 15, immagine 2 di 3 Sonos Play 5 Antenna Replacement: passo 15, immagine 3 di 3
  16. Sonos Play 5 Antenna Replacement: passo 16, immagine 1 di 3 Sonos Play 5 Antenna Replacement: passo 16, immagine 2 di 3 Sonos Play 5 Antenna Replacement: passo 16, immagine 3 di 3
    • Lift each board and hang over the side.
  17. Sonos Play 5 Antenna Replacement: passo 17, immagine 1 di 3 Sonos Play 5 Antenna Replacement: passo 17, immagine 2 di 3 Sonos Play 5 Antenna Replacement: passo 17, immagine 3 di 3
    • Remove first rubber strain relief by pinching the rubber then lifting up and away.
  18. Sonos Play 5 Antenna Replacement: passo 18, immagine 1 di 3 Sonos Play 5 Antenna Replacement: passo 18, immagine 2 di 3 Sonos Play 5 Antenna Replacement: passo 18, immagine 3 di 3
    • Remove second rubber strain relief by pinching the rubber then lifting up and away.
  19. Sonos Play 5 Antenna Replacement: passo 19, immagine 1 di 3 Sonos Play 5 Antenna Replacement: passo 19, immagine 2 di 3 Sonos Play 5 Antenna Replacement: passo 19, immagine 3 di 3
    • Remove third rubber strain relief by pinching the rubber then lifting up and away.
Conclusione
USF Tampa, Team S3-G6, Sullivan Spring 2017 Membro di USF Tampa, Team S3-G6, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G6
4 Membri
16 Guide realizzate
Un commento
Where do you buy the replacement antennas?
thomaspmunster - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 31
Tutti i Tempi: 4,431
