Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
The tweeter speaker is used to amplify high sounds. If your music sounds noticeably deep, there may be an issue with the tweeter and it will need to be replaced.
  1. Insert a spudger along the edge of the screen and gently use it to pull the screen away from the casing. Slide the spudger along the length of the grill to detach all the clips holding it in place. Insert a spudger along the edge of the screen and gently use it to pull the screen away from the casing. Slide the spudger along the length of the grill to detach all the clips holding it in place.
    • Insert a spudger along the edge of the screen and gently use it to pull the screen away from the casing. Slide the spudger along the length of the grill to detach all the clips holding it in place.
  2. Gently pull the screen away from the body of the speaker, revealing the tweeter and two mid-range drivers behind it.
    • Gently pull the screen away from the body of the speaker, revealing the tweeter and two mid-range drivers behind it.
    • There may be a kind of black sticky adhesive holding the screen clips to the rest of the body; however, it was previously removed on our model.
  3. Unscrew eight 1.5 inch Phillips #2 screws attaching the front speaker panel to the box. Unscrew the single 1 inch Phillips #2 screw located on the left side of the panel. This may be hidden beneath the warranty void sticker that you'll want to remove.
    • Unscrew eight 1.5 inch Phillips #2 screws attaching the front speaker panel to the box.
    • Unscrew the single 1 inch Phillips #2 screw located on the left side of the panel. This may be hidden beneath the warranty void sticker that you'll want to remove.
    • Unscrew the single 3/4 inch Phillips #2 screw, which is the last thing holding the front panel to the casing.
  4. Remove the front panel carefully. Note that there are two layers to the panel that should stay in their original order. Note that there are two layers to the panel that should stay in their original order.
    • Remove the front panel carefully.
    • Note that there are two layers to the panel that should stay in their original order.
  5. Disconnect the front panel from the motherboard by gently reaching in and pushing the tab underneath the wire connector and pulling towards you. Disconnect the front panel from the motherboard by gently reaching in and pushing the tab underneath the wire connector and pulling towards you.
    • Disconnect the front panel from the motherboard by gently reaching in and pushing the tab underneath the wire connector and pulling towards you.
  6. Gently remove the wireless card located at the bottom of the front speaker panel by pulling up and out with your index finger and thumb. Gently remove the wireless card located at the bottom of the front speaker panel by pulling up and out with your index finger and thumb.
    • Gently remove the wireless card located at the bottom of the front speaker panel by pulling up and out with your index finger and thumb.
  7. Use tweezers to disconnect the wire connectors from the tweeter speaker. The connectors may be very tight, but we promise they do come off. Use tweezers to disconnect the wire connectors from the tweeter speaker. The connectors may be very tight, but we promise they do come off. Use tweezers to disconnect the wire connectors from the tweeter speaker. The connectors may be very tight, but we promise they do come off.
    • Use tweezers to disconnect the wire connectors from the tweeter speaker. The connectors may be very tight, but we promise they do come off.
  8. Using a Phillips #2 screwdriver, remove the screws securing the speaker to the front panel.
    • Using a Phillips #2 screwdriver, remove the screws securing the speaker to the front panel.
  9. Carefully lift the tweeter speaker out the front of the panel. Carefully lift the tweeter speaker out the front of the panel.
    • Carefully lift the tweeter speaker out the front of the panel.
Conclusione
Altre 4 persone hanno completato questa guida.
Christina Santini
Membro da: 14/04/2016
1.245 Reputazione
7 Guide realizzate
Cal Poly, Team 25-6, Maness Spring 2016 Membro di Cal Poly, Team 25-6, Maness Spring 2016
CPSU-MANESS-S16S25G6
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 20
Tutti i Tempi: 692
