Salta al contenuto principale
Sonos Play 3 Mid-Range Speakers Replacement
Cosa ti serve
  1. Sonos Play 3 Mid-Range Speakers Replacement, Speaker Grille: passo 1, immagine 1 di 2 Sonos Play 3 Mid-Range Speakers Replacement, Speaker Grille: passo 1, immagine 2 di 2
    • Insert a spudger along the edge of the screen and gently use it to pull the screen away from the casing. Slide the spudger along the length of the grill to detach all the clips holding it in place.
  2. Sonos Play 3 Mid-Range Speakers Replacement: passo 2, immagine 1 di 1
    • Gently pull the screen away from the body of the speaker, revealing the tweeter and two mid-range drivers behind it.
    • There may be a kind of black sticky adhesive holding the screen clips to the rest of the body; however, it was previously removed on our model.
  3. Sonos Play 3 Mid-Range Speakers Replacement, Front Speaker Panel: passo 3, immagine 1 di 2 Sonos Play 3 Mid-Range Speakers Replacement, Front Speaker Panel: passo 3, immagine 2 di 2
    • Unscrew eight 1.5 inch Phillips #2 screws attaching the front speaker panel to the box.
    • Unscrew the single 1 inch Phillips #2 screw located on the left side of the panel. This may be hidden beneath the warranty void sticker that you'll want to remove.
    • Unscrew the single 3/4 inch Phillips #2 screw, which is the last thing holding the front panel to the casing.
  4. Sonos Play 3 Mid-Range Speakers Replacement: passo 4, immagine 1 di 3 Sonos Play 3 Mid-Range Speakers Replacement: passo 4, immagine 2 di 3 Sonos Play 3 Mid-Range Speakers Replacement: passo 4, immagine 3 di 3
    • Remove the front panel carefully.
    • Note that there are two layers to the panel that should stay in their original order.
  5. Sonos Play 3 Mid-Range Speakers Replacement: passo 5, immagine 1 di 2 Sonos Play 3 Mid-Range Speakers Replacement: passo 5, immagine 2 di 2
    • Disconnect the front panel from the motherboard by gently reaching in and pushing the tab underneath the wire connector and pulling towards you.
  6. Sonos Play 3 Mid-Range Speakers Replacement: passo 6, immagine 1 di 2 Sonos Play 3 Mid-Range Speakers Replacement: passo 6, immagine 2 di 2
    • Gently remove the wireless card located at the bottom of the front speaker panel by pulling up and out with your index finger and thumb.
  7. Sonos Play 3 Mid-Range Speakers Replacement, Mid-Range Speakers: passo 7, immagine 1 di 3 Sonos Play 3 Mid-Range Speakers Replacement, Mid-Range Speakers: passo 7, immagine 2 di 3 Sonos Play 3 Mid-Range Speakers Replacement, Mid-Range Speakers: passo 7, immagine 3 di 3
    • Use tweezers to disconnect the wire connectors from the mid-range speakers. The connectors may be very tight, but we promise they do come off.
  8. Sonos Play 3 Mid-Range Speakers Replacement: passo 8, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove the screws securing the speakers to the front panel.
  9. Sonos Play 3 Mid-Range Speakers Replacement: passo 9, immagine 1 di 2 Sonos Play 3 Mid-Range Speakers Replacement: passo 9, immagine 2 di 2
    • Carefully lift the speaker you need to replace out the front of the panel.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 25-6, Maness Spring 2016 Membro di Cal Poly, Team 25-6, Maness Spring 2016
CPSU-MANESS-S16S25G6
4 Membri
14 Guide realizzate
6 Commenti
What’s the point of taking the speaker out, if I can’t buy a replacement?
Peter - Replica
hi! where can i buy a replacement speaker?
Kareem - Replica
Christina, where did you get the replacement speaker??? What is the point of the how to without the parts??
wedevets - Replica
Dove posso trovare i ricambi sonos
Giustino - Replica
Successful driver replacement !
I dropped my Play 3 about a month ago. Both of the mid range drivers suffered damage. The magnets pulled the cones off center. I was able to reset one of the cones and it tested ok. The other unit not so much. I bought 2 drivers from AliExpress, deciding to replace both anyway . They arrived in 3 weeks, fit perfectly in the enclosure and the wire connectors needed no mods either. The replacements took about 10-15 minutes to install and the Play 3 is now playing beautifully! Link for the drivers:
https://www.aliexpress.com/item/22518326...
Doug Field - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 28
Tutti i Tempi: 4,831
