Salta al contenuto principale
Sonos Play 1 Tweeter Speaker Replacement
Cosa ti serve
  1. Sonos Play 1 Tweeter Speaker Replacement, Exterior Screen: passo 1, immagine 1 di 2 Sonos Play 1 Tweeter Speaker Replacement, Exterior Screen: passo 1, immagine 2 di 2
    • Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
    • Once you pry open one end, use precision tweezers to remove rubber footing.
  2. Sonos Play 1 Tweeter Speaker Replacement: passo 2, immagine 1 di 2 Sonos Play 1 Tweeter Speaker Replacement: passo 2, immagine 2 di 2
    • Using a metal spudger, pry open a corner of the adhesive tape.
    • Use precision tweezers to remove the adhesive tape.
  3. Sonos Play 1 Tweeter Speaker Replacement: passo 3, immagine 1 di 2 Sonos Play 1 Tweeter Speaker Replacement: passo 3, immagine 2 di 2
    • Remove the four 10 mm Torx security #10 screws that hold the base together.
    • Remove the base by lifting it vertically away from the bulk of the device.
  4. Sonos Play 1 Tweeter Speaker Replacement: passo 4, immagine 1 di 2 Sonos Play 1 Tweeter Speaker Replacement: passo 4, immagine 2 di 2
    • Remove the 10 mm Torx security #10 screw that holds down the exterior screen.
    • Using precision tweezers, remove the metal bracket.
  5. Sonos Play 1 Tweeter Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the exterior screen by lifting it away from the bulk of the device.
  6. Sonos Play 1 Tweeter Speaker Replacement, Sonos Play 1 Top Cover Disassembly: passo 6, immagine 1 di 1
    • Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
  7. Sonos Play 1 Tweeter Speaker Replacement: passo 7, immagine 1 di 3 Sonos Play 1 Tweeter Speaker Replacement: passo 7, immagine 2 di 3 Sonos Play 1 Tweeter Speaker Replacement: passo 7, immagine 3 di 3
    • Using a plastic opening tool, pry open the top cap containing the power and volume button.
    • Vertically remove the top cap.
    • Be sure to not jerk the top cap when removing , as to not damage the cable linking the switchboard to the motherboard.
  8. Sonos Play 1 Tweeter Speaker Replacement: passo 8, immagine 1 di 2 Sonos Play 1 Tweeter Speaker Replacement: passo 8, immagine 2 di 2
    • Using a plastic opening tool, pry open the circuit flap.
    • Once flap is loosened, use your hand to remove the circuit wire.
  9. Sonos Play 1 Tweeter Speaker Replacement, Disassembling Sonos Play 1 Rear Housing Cover: passo 9, immagine 1 di 2 Sonos Play 1 Tweeter Speaker Replacement, Disassembling Sonos Play 1 Rear Housing Cover: passo 9, immagine 2 di 2
    • Using a plastic opening tool, remove the grey tape from both sides of the device.
  10. Sonos Play 1 Tweeter Speaker Replacement: passo 10, immagine 1 di 2 Sonos Play 1 Tweeter Speaker Replacement: passo 10, immagine 2 di 2
    • Remove the six 9 mm Torx #9 screws.
    • Using a plastic opening tool, detach the rear housing cover from the housing.
    • Try not to jerk the rear housing cover, as its wires are still connected to delicate electronics.
  11. Sonos Play 1 Tweeter Speaker Replacement: passo 11, immagine 1 di 2 Sonos Play 1 Tweeter Speaker Replacement: passo 11, immagine 2 di 2
    • Using tweezers, grip the connector fixed to the motherboard's audio cable.
    • While pulling on the connector, detach the cable by pressing the connectors release.
  12. Sonos Play 1 Tweeter Speaker Replacement: passo 12, immagine 1 di 1
    • Using your fingers, grip the connector fixed to the motherboards power cable and detach it.
    • You will now be able to remove the rear housing cover.
  13. Sonos Play 1 Tweeter Speaker Replacement, Mid-Woofer speaker: passo 13, immagine 1 di 1
    • Remove the two 9mm Torx #9 screws fastening the power cable to the housing.
    • Remove the power cable.
  14. Sonos Play 1 Tweeter Speaker Replacement: passo 14, immagine 1 di 1
    • Using a metal spudger, press the release located in the center of the connector .
    • While pressing the release pull on the connector detaching it from the speaker.
    • Do this for both connections.
  15. Sonos Play 1 Tweeter Speaker Replacement: passo 15, immagine 1 di 2 Sonos Play 1 Tweeter Speaker Replacement: passo 15, immagine 2 di 2
    • Using the Torx T20 bit remove the four 13 mm screws fastening the speaker to the housing.
    • Remove the speaker by lifting it up towards the top of the housing and out at an angle.
  16. Sonos Play 1 Tweeter Speaker Replacement, Tweeter Speaker: passo 16, immagine 1 di 2 Sonos Play 1 Tweeter Speaker Replacement, Tweeter Speaker: passo 16, immagine 2 di 2
    • Using a metal spudger, press down on the clips that lock the input wires to the amplifier.
    • Once unlocked, pull back on the wires to remove them.
  17. Sonos Play 1 Tweeter Speaker Replacement: passo 17, immagine 1 di 2 Sonos Play 1 Tweeter Speaker Replacement: passo 17, immagine 2 di 2
    • Using a screwdriver, remove the four 10 mm Torx Security #10 screws.
    • Using your fingers, remove the tweeter from the front of the housing.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 8-4, Eyestone Fall 2015 Membro di USF Tampa, Team 8-4, Eyestone Fall 2015
USFT-EYESTONE-F15S8G4
4 Membri
16 Guide realizzate
3 Commenti
Can anybody recommend a source for a replacement tweeter speaker with comparable specs? Unless I missed something, this article doesn't address that, and that's kind of an important piece of the puzzle.
John Martinez - Replica
You can get them from Aliexpress for about 10€.
Stanton Attree - Replica
How do I look for the speaker replacement, what characteristics should I indicate because I can't find it, greetings
Gerardo Arguedas - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 33
Tutti i Tempi: 8,842
