Introduzione
The mid-woofer ensures the faithful reproduction of mid-range frequencies crucial for accurate playback of vocals and instruments, while also delivering a deep, rich bass. If it seizes to function the audio out put of the device will be greatly inhibited. This guide gives a step by step procedure on how to dismantle and replace the mid-woofer speaker.
Cosa ti serve
Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
Using a plastic opening tool, remove the grey tape from both sides of the device.
Remove the two 9mm Torx #9 screws fastening the power cable to the housing.
Remove the power cable.
Altre 15 persone hanno completato questa guida.
41 Commenti
Step 12 omits the connection to the Wi-Fi board. It's attached behind the hand in the picture and removing two T7 screws lets it slide out.
Where can i buy a new mid-woofer speaker?
Hi you have notice for midWoofer? asmaccocell@gmail.com
asmacco -
Nice guide. But without a matching replacement speaker, or at least specifications, it is useless. Even worse: without opening my Play:1 would be accepted at Sonos support :(
true true ))
totally pointless
whats the specs to replace the subwoofer
montpc74 -
