Introduzione
This guide is for the replacement of tweeter diaphragm for the Sonos One.
Important: Accessing the internals of the Sonos One will void the factory warranty and make the unit rejected for factory repair, even if warranty is expired.
  1. Disconnect all power cords.
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
  2. Remove the four 10mm Torx T10 screws from the bottom of the speaker.
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
    • Slide the protective cover upwards to remove.
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
    • Pull the control panel away from the speaker to separate.
    • Remove the six 9mm Torx T8 screws from the motherboard panel.
    • Using a plastic opening tool, separate the motherboard from the speaker.
    • Using your thumb, disconnect the speaker cable from the motherboard.
    • Disconnect the power adapter plug from the motherboard using your thumb.
    • Using the pointed end of the spudger, disconnect the red, green, and yellow cables connecting the WiFi transmitter/receiver.
    • Remove the motherboard panel from the speaker housing.
    • The woofer is highly magnetic, making removal of the metal screws sometimes difficult.
    • Remove the two 9mm Torx T8 screws from the power adapter plug.
    • Remove the power adapter receptacle from its housing slot.
    • Disconnect the woofer cables.
    • If removing the tabs is difficult, the flat end of the spudger may be used to depress the middle tab and then the tab may be pulled to disconnect.
    • Disconnect the cables from the tweeter.
    • Remove the four 10mm Torx T10 screws from the tweeter.
    • Remove the tweeter from the speaker housing.
Conclusione
Marcus Glowa
Membro da: 14/02/2018
653 Reputazione
5 Guide realizzate
USF Tampa, Team S2-G1, Nance Spring 2018 Membro di USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Membri
5 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 72
Tutti i Tempi: 340
