Salta al contenuto principale
Sonos One Protective Cover Replacement
Cosa ti serve
  1. Sonos One Protective Cover Replacement, Protective Cover: passo 1, immagine 1 di 3 Sonos One Protective Cover Replacement, Protective Cover: passo 1, immagine 2 di 3 Sonos One Protective Cover Replacement, Protective Cover: passo 1, immagine 3 di 3
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
  2. Sonos One Protective Cover Replacement: passo 2, immagine 1 di 3 Sonos One Protective Cover Replacement: passo 2, immagine 2 di 3 Sonos One Protective Cover Replacement: passo 2, immagine 3 di 3
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
  3. Sonos One Protective Cover Replacement: passo 3, immagine 1 di 2 Sonos One Protective Cover Replacement: passo 3, immagine 2 di 2
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  4. Sonos One Protective Cover Replacement: passo 4, immagine 1 di 3 Sonos One Protective Cover Replacement: passo 4, immagine 2 di 3 Sonos One Protective Cover Replacement: passo 4, immagine 3 di 3
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
  5. Sonos One Protective Cover Replacement: passo 5, immagine 1 di 2 Sonos One Protective Cover Replacement: passo 5, immagine 2 di 2
    • Slide the protective cover upwards to remove.
Conclusione
Altre 2 persone hanno completato questa guida.
Marcus Glowa
Membro da: 02/14/18
848 Reputazione
5 Guide realizzate
USF Tampa, Team S2-G1, Nance Spring 2018 Membro di USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Membri
6 Guide realizzate
Un commento
Well done! I would add a little bit about how much adhesive there is underneath the rubber feet as well as the screw cover.
Joshua Pinter - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 61
Tutti i Tempi: 4,602
