Salta al contenuto principale
Soft Leather Journal Cover Replacement
Cosa ti serve
  1. Soft Leather Journal Cover Replacement, Cover: passo 1, immagine 1 di 2 Soft Leather Journal Cover Replacement, Cover: passo 1, immagine 2 di 2
    • Gather your old journal, required tools and parts, and a large item that can be used as a weight.
    • Your stiff fabric will reinforce the spine, and your scrap leather will become your new cover. They can be different materials as long as they serve a similar function.
  2. Soft Leather Journal Cover Replacement: passo 2, immagine 1 di 3 Soft Leather Journal Cover Replacement: passo 2, immagine 2 di 3 Soft Leather Journal Cover Replacement: passo 2, immagine 3 di 3
    • Cut the cover and spine off from the main journal body with an X-ACTO knife.
    • Keep the main block of pages intact.
    • Save the cover for Step 5.
  3. Soft Leather Journal Cover Replacement: passo 3, immagine 1 di 1
    • Create the spine reinforcement:
    • Measure the height and width of the journal's spine onto your stiff fabric.
    • Subtract one inch from your height, and add two inches to your width.
  4. Soft Leather Journal Cover Replacement: passo 4, immagine 1 di 1
    • Cut the stiff fabric into a small rectangle with your modified measurements.
  5. Soft Leather Journal Cover Replacement: passo 5, immagine 1 di 3 Soft Leather Journal Cover Replacement: passo 5, immagine 2 di 3 Soft Leather Journal Cover Replacement: passo 5, immagine 3 di 3
    • Apply a thin layer of PVA glue to the spine of the journal with a paintbrush.
    • Press the spine firmly into the center of the stiff fabric for one minute.
    • PVA glue dries fast, so work quickly.
  6. Soft Leather Journal Cover Replacement: passo 6, immagine 1 di 3 Soft Leather Journal Cover Replacement: passo 6, immagine 2 di 3 Soft Leather Journal Cover Replacement: passo 6, immagine 3 di 3
    • Create the new cover:
    • Press the original cover flat onto the interior of your scrap leather.
    • Trace around the original cover with chalk.
  7. Soft Leather Journal Cover Replacement: passo 7, immagine 1 di 3 Soft Leather Journal Cover Replacement: passo 7, immagine 2 di 3 Soft Leather Journal Cover Replacement: passo 7, immagine 3 di 3
    • Cut on the chalk outline with scissors, extending the length beyond the right side by four inches.
    • This extra length will become the cover flap.
  8. Soft Leather Journal Cover Replacement: passo 8, immagine 1 di 3 Soft Leather Journal Cover Replacement: passo 8, immagine 2 di 3 Soft Leather Journal Cover Replacement: passo 8, immagine 3 di 3
    • Roll the journal onto the new cover to ensure a correct fit.
  9. Soft Leather Journal Cover Replacement: passo 9, immagine 1 di 2 Soft Leather Journal Cover Replacement: passo 9, immagine 2 di 2
    • Spread a thin, even layer of PVA glue onto the front and back of the journal.
    • Make sure to coat the overhang of the stiff fabric, but DO NOT glue the spine.
  10. Soft Leather Journal Cover Replacement: passo 10, immagine 1 di 3 Soft Leather Journal Cover Replacement: passo 10, immagine 2 di 3 Soft Leather Journal Cover Replacement: passo 10, immagine 3 di 3
    • Left align the journal (front-side down) onto the interior of your new cover, spine facing towards the center.
    • Gently roll the journal onto its back sheet until it meets the chalk line.
    • Place a weight on top of the journal for at least 30 minutes.
  11. Soft Leather Journal Cover Replacement: passo 11, immagine 1 di 3 Soft Leather Journal Cover Replacement: passo 11, immagine 2 di 3 Soft Leather Journal Cover Replacement: passo 11, immagine 3 di 3
    • Create the string closure:
    • Trace an 18-inch long by half-inch tall rectangle onto the interior of your excess scrap leather.
  12. Soft Leather Journal Cover Replacement: passo 12, immagine 1 di 2 Soft Leather Journal Cover Replacement: passo 12, immagine 2 di 2
    • Cut on the chalk outline.
  13. Soft Leather Journal Cover Replacement: passo 13, immagine 1 di 2 Soft Leather Journal Cover Replacement: passo 13, immagine 2 di 2
    • Cut two, half-inch tall vertical slits into the front flap of the new cover. Center them with one inch between each slit.
  14. Soft Leather Journal Cover Replacement: passo 14, immagine 1 di 3 Soft Leather Journal Cover Replacement: passo 14, immagine 2 di 3 Soft Leather Journal Cover Replacement: passo 14, immagine 3 di 3
    • Thread the string closure through the slits so that the ends sit on top of the cover flap.
    • Pull until two inches remain on the left side.
    • Gently tie the journal closed.
  15. Soft Leather Journal Cover Replacement: passo 15, immagine 1 di 1
    • Congratulations! Your new journal is ready to use.
Linea Traguardo
UC Davis, Team 2-1, Andersen Winter 2025 Membro di UC Davis, Team 2-1, Andersen Winter 2025
UCD-ANDERSEN-W25S2G1
3 Membri
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 245
