Salta al contenuto principale
SodaStream Fountain Jet A200 Spring Replacement
  1. SodaStream Fountain Jet A200 Spring Replacement, removing back cover: passo 1, immagine 1 di 2 SodaStream Fountain Jet A200 Spring Replacement, removing back cover: passo 1, immagine 2 di 2
    • Press in the two gray buttons found on either side, at the top of the machine.
    • Pull back on the cover until it releases from the device and pull the back off.
  2. SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: passo 2, immagine 1 di 2 SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: passo 2, immagine 2 di 2
    • Place your hand under the carbonation button and gently pull up and away from you, towards the back of the machine.
  3. SodaStream Fountain Jet A200 Spring Replacement, spring removal: passo 3, immagine 1 di 2 SodaStream Fountain Jet A200 Spring Replacement, spring removal: passo 3, immagine 2 di 2
    • Remove the spring located under the carbonation button.
    • Replace with the new spring, by lining it up and pushing it down.
Conclusione
Altre 5 persone hanno completato questa guida.
2 Commenti
Does anyone know where I can get a carbonation button?
draganr@wi.rr.com
draganr - Replica
Do we know the spring parameters?
Outside Diameter
Inside Diameter
Overall Length
Wire Diameter
Total # of Coils
Active # of Coils
Solid Height
Space between the Coils
John Friedman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 33
Tutti i Tempi: 9,889
