Salta al contenuto principale
Snowboard Binding Replacement
Cosa ti serve
  1. Snowboard Binding Replacement, Binding: passo 1, immagine 1 di 3 Snowboard Binding Replacement, Binding: passo 1, immagine 2 di 3 Snowboard Binding Replacement, Binding: passo 1, immagine 3 di 3
    • Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
    • Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
  2. Snowboard Binding Replacement: passo 2, immagine 1 di 2 Snowboard Binding Replacement: passo 2, immagine 2 di 2
    • Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
    • The highback plate is the vertical support plate located on the heel side of the binding.
  3. Snowboard Binding Replacement: passo 3, immagine 1 di 2 Snowboard Binding Replacement: passo 3, immagine 2 di 2
    • Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
  4. Snowboard Binding Replacement: passo 4, immagine 1 di 3 Snowboard Binding Replacement: passo 4, immagine 2 di 3 Snowboard Binding Replacement: passo 4, immagine 3 di 3
    • Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
    • Lift or slide the binding off the board and set the screws aside.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 17-4, Forte Winter 2014 Membro di Cal Poly, Team 17-4, Forte Winter 2014
CPSU-FORTE-W14S17G4
5 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 204
Tutti i Tempi: 15,348
