Salta al contenuto principale
Snowboard Binding Replacement
Cosa ti serve
  1. Snowboard Binding Replacement, Binding: passo 1, immagine 1 di 1
    • Start by having the new snowboard binding and screws set aside. Make sure to also have a standard Phillips screwdriver.
  2. Snowboard Binding Replacement: passo 2, immagine 1 di 1
    • First, align the screw and attach the plastic strip.
  3. Snowboard Binding Replacement: passo 3, immagine 1 di 1
    • Then begin to tighten the plastic strip by using the screwdriver with one hand and then holding the nut with the other to tighten the plastic strip.
  4. Snowboard Binding Replacement: passo 4, immagine 1 di 1
    • This is what it should look like so far.
  5. Snowboard Binding Replacement: passo 5, immagine 1 di 1
    • Now we will begin to attach the strap to the opposite side. Like previously, you will need a screwdriver to tighten the strap once you have aligned the screw and attached the nut on the other side.
  6. Snowboard Binding Replacement: passo 6, immagine 1 di 1
    • Make sure to not tighten it too much as the strap needs to be able to move slightly.
  7. Snowboard Binding Replacement: passo 7, immagine 1 di 1
    • Once everything is tightened properly this is what it should look like. Congrats you have successfully repaired a snowboard binding!!!
    • Now it's time to take a picture with your fix!
Conclusione
Justin
Membro da: 04/13/22
157 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 218
