Salta al contenuto principale
Smartab STJR700 Screen/Digitizer Replacement
Cosa ti serve
  1. Smartab STJR700 Screen/Digitizer Replacement, Screen/Digitizer: passo 1, immagine 1 di 2 Smartab STJR700 Screen/Digitizer Replacement, Screen/Digitizer: passo 1, immagine 2 di 2
    • There are four screws with each one in each corner. Use the screwdriver to unscrew the back or bottom of the device.
  2. Smartab STJR700 Screen/Digitizer Replacement: passo 2, immagine 1 di 1
    • Remove the bottom or back of the device by detaching the black bottom after removing the screws.
    • the front panel should now be exposing the digitizer along with the other electronic components of the device.
  3. Smartab STJR700 Screen/Digitizer Replacement: passo 3, immagine 1 di 2 Smartab STJR700 Screen/Digitizer Replacement: passo 3, immagine 2 di 2
    • Next, remove the circuit board from the front panel and screen. This should leave the digitizer and circuit board intact.
    • Afterward, remove the existing damaged glass part of the device from the front panel as shown in the last picture.
    • Finally add a new STJR700 screen and reverse the previous steps to reattach the device.
Conclusione
Tianna Edwards
Membro da: 03/22/17
128 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,140
