Salta al contenuto principale
Smartab STJR700 Charging Port Replacement
Cosa ti serve
  1. Smartab STJR700 Charging Port Replacement, Charging Port: passo 1, immagine 1 di 1
    • Power off the device by holding down the lock button. Remove the case from the tablet and place it face down.
  2. Smartab STJR700 Charging Port Replacement: passo 2, immagine 1 di 1
    • Unscrew all four corner screws using the PH000 screwdriver head found in the iFixit kit.
  3. Smartab STJR700 Charging Port Replacement: passo 3, immagine 1 di 1
    • CAUTION: Avoid touching the display.
    • Pry open the tablet using a metal spudger. Set aside the back panel.
  4. Smartab STJR700 Charging Port Replacement: passo 4, immagine 1 di 1
    • Locate the charging port.
  5. Smartab STJR700 Charging Port Replacement: passo 5, immagine 1 di 2 Smartab STJR700 Charging Port Replacement: passo 5, immagine 2 di 2
    • Unscrew all the labeled screws using the PH000 screwdriver head.
  6. Smartab STJR700 Charging Port Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove all pieces of tape using the tweezers provided in the iFixit kit.
    • Remove the two ribbon cables affixed to the camera.
  7. Smartab STJR700 Charging Port Replacement: passo 7, immagine 1 di 1
    • Remove the motherboard component from the screen and display.
    • Because the charging port is soldered onto the motherboard, the motherboard must be replaced by one specifically made for the Smartab STJR700.
Conclusione
Thi Le
Membro da: 03/08/17
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 982
