Salta al contenuto principale
Smartab STJR700 Back Camera Lens Replacement
Cosa ti serve
  1. Smartab STJR700 Back Camera Lens Replacement, Back Camera Lens: passo 1, immagine 1 di 2 Smartab STJR700 Back Camera Lens Replacement, Back Camera Lens: passo 1, immagine 2 di 2
    • First, use a screwdriver to remove the screws on the back cover of the Smartab.
    • Next, carefully remove the cover to reveal the inside of the tablet.
  2. Smartab STJR700 Back Camera Lens Replacement: passo 2, immagine 1 di 3 Smartab STJR700 Back Camera Lens Replacement: passo 2, immagine 2 di 3 Smartab STJR700 Back Camera Lens Replacement: passo 2, immagine 3 di 3
    • When you open the tablet, you will see several components.
    • You will see that the camera is stabilized by screws. The digitizer is held in place using black tape.
    • When the black tape is peeled back, you will see that the digitizer is also connected to the motherboard.
  3. Smartab STJR700 Back Camera Lens Replacement: passo 3, immagine 1 di 3 Smartab STJR700 Back Camera Lens Replacement: passo 3, immagine 2 di 3 Smartab STJR700 Back Camera Lens Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use a screwdriver to unscrew the camera from the tablet.
    • Use tweezers to remove the digitizer from the hard drive.
    • After the digitizer is removed and the camera is unscrewed, remove them from the tablet.
    • Replace the old camera with a replacement camera by using a screwdriver. Replace the old digitizer with a replacement digitizer by using a soldering tool.
    • To replace the camera lens, start by removing the broken glass by using tweezers.
    • If the new lens has adhesive, make sure that all the old adhesive is removed from the frame so that the lens does not stick out, and so a tighter seal is formed.
    • Once the glass is removed, place the new camera lense by peeling off the upper film and align the glass with the ring.
Conclusione
Fatu Woodson
Membro da: 03/08/17
101 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 457
