Salta al contenuto principale
Smart Tweezers and LCR-Reader LCR-meter Screen Replacement
Cosa ti serve
  1. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Opening the device: passo 1, immagine 1 di 2 Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Opening the device: passo 1, immagine 2 di 2
    • Start by removing the 4 screws in the back of the device using a size 00 Philips screw driver.
  2. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Replacing the screen: passo 2, immagine 1 di 2 Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Replacing the screen: passo 2, immagine 2 di 2
    • Gently open the zif connector that holds the screen.
    • Insert the replacement screen, and close the zif
  3. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Closing the device: passo 3, immagine 1 di 1
    • When closing the housing, make sure the screen fits into the rectangle on the top.
    • If the screen is not in this rectangle, it may become damaged when the screws are tightened
    • Hold the screen in place from below; line up the button's edge of the top housing to line up with the bottom housing. Slide your finger out as you bring the top and bottom housings to meet.
    • Replace the 4 Philips screws in the back.
Linea Traguardo
brittany
Membro da: 07/16/12
234 Reputazione
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 552
