Introduzione
Before opening the LCR-Reader, place a small bit of tape over the button on the top housing. This will keep the button from falling loose and being lost.
Start by removing the 4 screws in the back of the device using a size 00 Philips screw driver.
  • Start by removing the 4 screws in the back of the device using a size 00 Philips screw driver.
Aggiungi Commento
Gently open the zif connector that holds the screen.
  • Gently open the zif connector that holds the screen.
  • Insert the replacement screen, and close the zif
Aggiungi Commento
  • When closing the housing, make sure the screen fits into the rectangle on the top.
  • If the screen is not in this rectangle, it may become damaged when the screws are tightened
  • Hold the screen in place from below; line up the button's edge of the top housing to line up with the bottom housing. Slide your finger out as you bring the top and bottom housings to meet.
  • Replace the 4 Philips screws in the back.
Aggiungi Commento
Linea Traguardo
brittany
Membro da: 16/07/2012
150 Reputazione
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 192
