Salta al contenuto principale
Skytex SP728 Speakers Replacement
Cosa ti serve
  1. Skytex SP728 Speakers Replacement, Case: passo 1, immagine 1 di 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Speakers Replacement: passo 2, immagine 1 di 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Speakers Replacement: passo 3, immagine 1 di 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Speakers Replacement: passo 4, immagine 1 di 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Speakers Replacement, Speakers: passo 5, immagine 1 di 1
    • Identify the connection location of the wires from the speakers.
  6. Skytex SP728 Speakers Replacement: passo 6, immagine 1 di 1
    • Use a soldering iron to remove the speaker wires from the circuit board
  7. Skytex SP728 Speakers Replacement: passo 7, immagine 1 di 1
    • Solder the new speakers to the correct location, making sure the red wire goes to the + and the black wire goes to the -.
Conclusione
Chris Nelson
Membro da: 01/21/15
213 Reputazione
2 Guide realizzate
USF Tampa, Team 5-1, Brown Winter 2015 Membro di USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 106
