Salta al contenuto principale
Skytex SP728 Antenna Replacement
Cosa ti serve
  1. Skytex SP728 Antenna Replacement, Case: passo 1, immagine 1 di 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Antenna Replacement: passo 2, immagine 1 di 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Antenna Replacement: passo 3, immagine 1 di 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Antenna Replacement: passo 4, immagine 1 di 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Antenna Replacement, Antenna: passo 5, immagine 1 di 1
    • Remove the case and open the device
  6. Skytex SP728 Antenna Replacement: passo 6, immagine 1 di 1
    • Remove the black tapes
  7. Skytex SP728 Antenna Replacement: passo 7, immagine 1 di 1
    • Use the soldering station and remove soldered connections to the antenna wires.
    • Now replace the antenna.
    • Follow the link below for additional soldering information "https://www.ifixit.com/Guide/How+To+Sold...
Conclusione
USF Tampa, Team 5-1, Brown Winter 2015 Membro di USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 106
