Salta al contenuto principale
Sky Thunder HD 8500WH Motor Replacement
Cosa ti serve
  1. Sky Thunder HD 8500WH Motor Replacement, Rotor Blade: passo 1, immagine 1 di 3 Sky Thunder HD 8500WH Motor Replacement, Rotor Blade: passo 1, immagine 2 di 3 Sky Thunder HD 8500WH Motor Replacement, Rotor Blade: passo 1, immagine 3 di 3
    • Place the drone with the top side facing up.
    • Remove the blade cover.
    • Remove the rotor blade.
  2. Sky Thunder HD 8500WH Motor Replacement, Lockstitch: passo 2, immagine 1 di 2 Sky Thunder HD 8500WH Motor Replacement, Lockstitch: passo 2, immagine 2 di 2
    • Unscrew the 1cm screw holding in the blade lockstitch with the Phillips 0 Screwdriver.
    • Remove the blade lockstitch.
  3. Sky Thunder HD 8500WH Motor Replacement, Lower and Upper Body: passo 3, immagine 1 di 3 Sky Thunder HD 8500WH Motor Replacement, Lower and Upper Body: passo 3, immagine 2 di 3 Sky Thunder HD 8500WH Motor Replacement, Lower and Upper Body: passo 3, immagine 3 di 3
    • Lay down the drone so the battery side is facing up.
    • Unscrew all 5 .8cm screws on each arm of the drone with the Phillips 0 Screwdriver.
    • Repeat previous bullet for each arm (20 screws in total).
  4. Sky Thunder HD 8500WH Motor Replacement: passo 4, immagine 1 di 2 Sky Thunder HD 8500WH Motor Replacement: passo 4, immagine 2 di 2
    • Using a bit of force, gently pull apart the lower and upper bodies.
    • Keep going until both parts are completely separated.
  5. Sky Thunder HD 8500WH Motor Replacement, Gear: passo 5, immagine 1 di 2 Sky Thunder HD 8500WH Motor Replacement, Gear: passo 5, immagine 2 di 2
    • Find the gear mechanism at the end of one of the drone arms.
    • Unscrew the two front .8cm screws with the Phillips 0 Screwdriver.
  6. Sky Thunder HD 8500WH Motor Replacement: passo 6, immagine 1 di 2 Sky Thunder HD 8500WH Motor Replacement: passo 6, immagine 2 di 2
    • Remove the white spacer.
    • Remove the red spacer.
  7. Sky Thunder HD 8500WH Motor Replacement: passo 7, immagine 1 di 1
    • Pull the gear out from the bottom of the holding mechanism.
  8. Sky Thunder HD 8500WH Motor Replacement, Motor: passo 8, immagine 1 di 2 Sky Thunder HD 8500WH Motor Replacement, Motor: passo 8, immagine 2 di 2
    • Unscrew the two .8cm screws on the bottom of the holding mechanism with the Phillips 0 Screwdriver.
    • Remove the motor from the holding mechanism.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 181
