Cosa ti serve
Place the drone with the top side facing up.
Remove the blade cover.
Remove the rotor blade.
Unscrew the 1cm screw holding in the blade lockstitch with the Phillips 0 Screwdriver.
Remove the blade lockstitch.
Lay down the drone so the battery side is facing up.
Unscrew all 5 .8cm screws on each arm of the drone with the Phillips 0 Screwdriver.
Repeat previous bullet for each arm (20 screws in total).
Altre 2 persone hanno completato questa guida.
