Salta al contenuto principale
Sky 6.0Q Front Camera Replacement
Cosa ti serve
  1. Sky 6.0Q Front Camera Replacement, Front Camera: passo 1, immagine 1 di 1
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Front Camera Replacement: passo 2, immagine 1 di 1
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Front Camera Replacement: passo 3, immagine 1 di 2 Sky 6.0Q Front Camera Replacement: passo 3, immagine 2 di 2
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Front Camera Replacement: passo 4, immagine 1 di 2 Sky 6.0Q Front Camera Replacement: passo 4, immagine 2 di 2
    • Disconnect the electronic adapter connecting the camera to the top mother board.
    • Once disconnected, remove the camera and replace with new camera. If necessary, use the spudger to help remove the camera.
    • To reattach front camera electrical connection, gently press piece back in place.
Conclusione
IUPUI, Team S1-G3, Hovde Fall 2018 Membro di IUPUI, Team S1-G3, Hovde Fall 2018
IUPUI-HOVDE-F18S1G3
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 285
