Salta al contenuto principale
Skullcandy Mix Master DJ Mylar Driver Replacement
Cosa ti serve
  1. Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: passo 1, immagine 1 di 3 Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: passo 1, immagine 2 di 3 Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: passo 1, immagine 3 di 3
    • With the plastic opening tool, separate the padded ear cup from the main speaker component.
    • Make sure to fold the ear cup inward to avoid getting in the way of the opposite side.
  2. Skullcandy Mix Master DJ Mylar Driver Replacement: passo 2, immagine 1 di 1
    • Using your screw driver, remove the six Philips 2mm screws located on the chrome ring.
  3. Skullcandy Mix Master DJ Mylar Driver Replacement: passo 3, immagine 1 di 2 Skullcandy Mix Master DJ Mylar Driver Replacement: passo 3, immagine 2 di 2
    • Using your screw driver, remove the four 3mm Phillips screws located on the grey speaker.
    • Remove the driver from the gray speaker assembly.
    • Carefully remove the driver assembly since there are wires connected to the headphone jack, headband, and mute button.
  4. Skullcandy Mix Master DJ Mylar Driver Replacement: passo 4, immagine 1 di 2 Skullcandy Mix Master DJ Mylar Driver Replacement: passo 4, immagine 2 di 2
    • Using your screw driver, remove the two 2mm Phillips screws located on the circuit panel of the audio jack.
    • Carefully separate the jack from the ear cup casing.
    • If you are working on the right ear cup, the mute button circuit board may be difficult to remove.
  5. Skullcandy Mix Master DJ Mylar Driver Replacement: passo 5, immagine 1 di 2 Skullcandy Mix Master DJ Mylar Driver Replacement: passo 5, immagine 2 di 2
    • The Mylar driver is connected to several small circuit boards by soldered wires. It can only be removed by cutting the connecting wires.
    • Do not pull the driver away too fast since there are wires connecting the driver to the ear cup.
    • Soldering Guide: https://www.youtube.com/watch?v=urGB_IUX...
Conclusione
Sean Herlihy
Membro da: 03/30/15
117 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,527
