Salta al contenuto principale
Skullcandy Lowrider Wiring Repair
Cosa ti serve
  1. Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: passo 1, immagine 1 di 3 Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: passo 1, immagine 2 di 3 Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: passo 1, immagine 3 di 3
    • If your wire is severed, the first step is removing the rubber coating to expose both ends of the severed wire.
    • Do this by wedging it in a sharp crevice and pulling at the rubber coating. It should strip just the rubber coating. The small wedge in a spudger should suffice.
  2. Skullcandy Lowrider Wiring Repair: passo 2, immagine 1 di 2 Skullcandy Lowrider Wiring Repair: passo 2, immagine 2 di 2
    • Now that the internal wires have been exposed, take one end and group all similarly colored wires together.
    • Do the same for the other severed wire.
  3. Skullcandy Lowrider Wiring Repair: passo 3, immagine 1 di 3 Skullcandy Lowrider Wiring Repair: passo 3, immagine 2 di 3 Skullcandy Lowrider Wiring Repair: passo 3, immagine 3 di 3
    • Twist the green wires from both ends of the severed wire together.
    • Cover in electrical tape.
  4. Skullcandy Lowrider Wiring Repair: passo 4, immagine 1 di 1
    • Do the same for all matching wires on both ends.
    • Cover completely in electrical tape.
Conclusione
Ryley
Membro da: 01/16/15
273 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 629
