Salta al contenuto principale
Skullcandy Air Raid USB Board Replacement
Cosa ti serve
  1. Skullcandy Air Raid USB Board Replacement, Rubber Cover: passo 1, immagine 1 di 1
    • Starting with the corners, gently pull the rubber cover off of the device.
  2. Skullcandy Air Raid USB Board Replacement, Handle: passo 2, immagine 1 di 1
    • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
    • Remove the handle from the device.
  3. Skullcandy Air Raid USB Board Replacement, Front Plate: passo 3, immagine 1 di 1
    • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
    • One 5mm Phillips screw.
    • One 8mm Phillips screw.
  4. Skullcandy Air Raid USB Board Replacement: passo 4, immagine 1 di 1
    • Gently pull the sides of the front plate outwards from the device.
    • Pull up on the front plate to remove it from the device.
  5. Skullcandy Air Raid USB Board Replacement, Speakers: passo 5, immagine 1 di 1
    • Using a #000 Philips Screwdriver, unscrew the four 8 mm Philips screws from each corner of both speakers (eight 8 mm Philips screws total).
  6. Skullcandy Air Raid USB Board Replacement: passo 6, immagine 1 di 1
    • Using the plastic opening tool, pry around edges of the speaker to loosen glue contact with front plate.
    • If you are unable to loosen glue contact using the plastic opening tool, use a heat gun to assist in removal.
  7. Skullcandy Air Raid USB Board Replacement: passo 7, immagine 1 di 1
    • Lift the speaker out of the device.
    • Be aware of the connection with the ribbon cable.
    • For reassembly, ensure proper orientation of the cable plug.
  8. Skullcandy Air Raid USB Board Replacement: passo 8, immagine 1 di 1
    • Firmly pull on the end of ribbon cable to disconnect the speaker from the motherboard.
  9. Skullcandy Air Raid USB Board Replacement, Control Buttons: passo 9, immagine 1 di 1
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, above and below volume buttons.
  10. Skullcandy Air Raid USB Board Replacement: passo 10, immagine 1 di 1
    • Lift the button panel.
  11. Skullcandy Air Raid USB Board Replacement, Button Motherboard: passo 11, immagine 1 di 1
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
  12. Skullcandy Air Raid USB Board Replacement: passo 12, immagine 1 di 1
    • Using a plastic opening tool, pry the button motherboard to detach it from the device.
    • The button motherboard is connected to a ribbon cable inside the device.
  13. Skullcandy Air Raid USB Board Replacement, Ribbon Cable: passo 13, immagine 1 di 1
    • Pull the black ribbon cord attachment away from the motherboard.
    • Pull on the cable until it releases from the back of the motherboard.
    • The black attachment is part of the connector, not the blue ribbon cable, so it will not disconnect from the motherboard.
  14. Skullcandy Air Raid USB Board Replacement, Back panel: passo 14, immagine 1 di 2 Skullcandy Air Raid USB Board Replacement, Back panel: passo 14, immagine 2 di 2
    • Using a Phillips #00 Precision Screwdriver, unscrew two 8 mm screws.
    • Lift off the back panel.
  15. Skullcandy Air Raid USB Board Replacement, Ribbon Cables: passo 15, immagine 1 di 1
    • Where the blue and white ribbon cable meets the motherboard, pull up on the black piece of the ribbon cable connector.
    • Pull the ribbon cable away from the motherboard.
  16. Skullcandy Air Raid USB Board Replacement: passo 16, immagine 1 di 1
    • Pull on grey and white ribbon cable until it disconnects from the motherboard.
  17. Skullcandy Air Raid USB Board Replacement, Left Divider: passo 17, immagine 1 di 3 Skullcandy Air Raid USB Board Replacement, Left Divider: passo 17, immagine 2 di 3 Skullcandy Air Raid USB Board Replacement, Left Divider: passo 17, immagine 3 di 3
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the left divider between the main cavity and the USB motherboard.
    • Pull out the USB/On Switch panel.
    • Pull out the Left Divider.
    • For reassembly, lift up on right side of motherboard to slide left divider back in place.
  18. Skullcandy Air Raid USB Board Replacement, USB Motherboard: passo 18, immagine 1 di 2 Skullcandy Air Raid USB Board Replacement, USB Motherboard: passo 18, immagine 2 di 2
    • Using a Phillips #00 Precision Screwdriver, unscrew two 5 mm Phillips-head screws from the USB motherboard.
    • Remove the metal clip.
Conclusione
Altre 2 persone hanno completato questa guida.
Cyrene
Membro da: 01/13/15
200 Reputazione
1 Guida realizzata
2 Commenti
Where can you purchase the replacement?
Mikail Lane - Replica
As far as I know,You can't!
Luke Thomas - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,438
