Introduzione
This disassembly includes the button panel and button motherboard.
Cosa ti serve
Starting with the corners, gently pull the rubber cover off of the device.
Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
Remove the handle from the device.
Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
One 5mm Phillips screw.
One 8mm Phillips screw.
Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, specifically above and below the volume buttons.
Lift the button panel.
Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
First, pull on the black attachment to disconnect it from the metal piece.
Release the cable from the back of the motherboard.
Altre 2 persone hanno completato questa guida.
