Salta al contenuto principale
SkullCandy Hesh Size Adjuster Replacement
Cosa ti serve
  1. SkullCandy Hesh Size Adjuster Replacement, Determine the damage: passo 1, immagine 1 di 2 SkullCandy Hesh Size Adjuster Replacement, Determine the damage: passo 1, immagine 2 di 2
    • Locate the break in the device.
  2. SkullCandy Hesh Size Adjuster Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the two 9 mm screws from the bottom inner casing beneath the break.
  3. SkullCandy Hesh Size Adjuster Replacement: passo 3, immagine 1 di 1
    • Remove the bottom inner casing to reveal the wire compartment and the port where the slider inserts.
  4. SkullCandy Hesh Size Adjuster Replacement: passo 4, immagine 1 di 2 SkullCandy Hesh Size Adjuster Replacement: passo 4, immagine 2 di 2
    • Cover the detached slider port in a generous layer of Plasti Dip, which works like glue. Also coat any exposed wire to seal the circuit.
  5. SkullCandy Hesh Size Adjuster Replacement: passo 5, immagine 1 di 1
    • Realign the broken size adjuster into the port with the Plasti Dip so that it can be secured to the ear piece.
  6. SkullCandy Hesh Size Adjuster Replacement: passo 6, immagine 1 di 1
    • Clamp the pieces in place by hand or with a binder clip until the Plasti Dip dries. Feel free to use a hair dryer on a low setting to speed up the process.
Conclusione
To reassemble your device, reattach the bottom inner casing with the Phillips #0 screwdriver and two removed screws.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 877
