Salta al contenuto principale
Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement
Cosa ti serve
  1. Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Un-clip Battery: passo 1, immagine 1 di 1
    • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  2. Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Battery: passo 2, immagine 1 di 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Battery: passo 2, immagine 2 di 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Battery: passo 2, immagine 3 di 3
    • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
  3. Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Handle: passo 3, immagine 1 di 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Handle: passo 3, immagine 2 di 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Handle: passo 3, immagine 3 di 3
    • Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill.
Conclusione
Sean
Membro da: 09/23/14
282 Reputazione
2 Guide realizzate
USF Tampa, Team 2-3, Blackwell Fall 2014 Membro di USF Tampa, Team 2-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G3
5 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 460
