Salta al contenuto principale
Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement
Cosa ti serve
  1. Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Un-clip Battery: passo 1, immagine 1 di 1
    • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  2. Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: passo 2, immagine 1 di 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: passo 2, immagine 2 di 3 Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: passo 2, immagine 3 di 3
    • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
Conclusione
Altre 4 persone hanno completato questa guida.
Sean
Membro da: 09/23/14
282 Reputazione
2 Guide realizzate
USF Tampa, Team 2-3, Blackwell Fall 2014 Membro di USF Tampa, Team 2-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G3
5 Membri
9 Guide realizzate
5 Commenti
my battery is stuck in the drill any ideas
yonko99 - Replica
My battery is also stuck. I see no replies. What now?
Bobby Verdier - Replica
Thank you, it really was easy !!!!!
Betty - Replica
My battery is stuck too. I read on another forum to use a screwdriver and hammer.
I’m a girl, so don’t take my advice, but wondering if you could you spray it with WD-40 to loosen it up?
Amy Dionne - Replica
Have you been able to get it out? On mine the button was hard to get all the way down. I used both thumbs and was eventually able to get it down far enough to get it off. I bumped it on my leg to help loosen it. If you use a hammer I would suggest using a rubber mallet so you don’t damage the battery or the drill.
Once it’s off clean up the slides real good, spray some WD40 on them, then wipe off with a rag. That should help prevent it from getting stuck again. I would spray a little WD40 on the button and work it back and forth as well.
Hope this helps
Brian Harrod -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 62
Tutti i Tempi: 6,124
