Introduzione
The old volume button is removed by pushing the pushing the volume button upwards and popping it out of the device's case. The new volume button is installed by simply snapping it into volume button slot of the case..
Strumenti
Parti
Nessuna parte specificata.
Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
Remove the front cover.
First, insert a small pry bar where the black front cover and white back cover meet.
Begin prying the black plastic up, slowing moving around to the bottom and other side.
At an angle, carefully pull up on the front cover separate the two pieces.
Excellent! Now you have removed the front cover!
While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
Locate the volume button on the side of the device. The volume button is indicated with an orange rectangle in the photograph.
Un commento
Because of the difference between two people in the morning but I'm going&@6899!12;;....,
