Salta al contenuto principale
Sink O-Ring Replacement
Cosa ti serve
  1. Sink O-Ring Replacement, O-Ring: passo 1, immagine 1 di 1
    • Locate both valves for hot and cold water. These are typically under the sink.
    • Turn off the water supply by turning each knob clockwise to stop the flow of water.
  2. Sink O-Ring Replacement: passo 2, immagine 1 di 1
    • Put on gloves, as mold might be present.
  3. Sink O-Ring Replacement: passo 3, immagine 1 di 1
    • Locate the screw insert in the sink handle.
  4. Sink O-Ring Replacement: passo 4, immagine 1 di 1
    • Take out your screwdriver and attach the appropriate bit for your screw.
  5. Sink O-Ring Replacement: passo 5, immagine 1 di 1
    • Insert the screwdriver into the screw in the sink handle, and rotate the screwdriver counterclockwise (left) to remove the screw.
  6. Sink O-Ring Replacement: passo 6, immagine 1 di 1
    • Gently, but firmly, pull out the sink handle once the screw is removed.
  7. Sink O-Ring Replacement: passo 7, immagine 1 di 2 Sink O-Ring Replacement: passo 7, immagine 2 di 2
    • Once the handle is separated from the sink, clean it and its interior with an antibacterial spray, such as Lysol or Clorox.
    • If the sink has been linked for some time, mold has likely accumulated.
  8. Sink O-Ring Replacement: passo 8, immagine 1 di 1
    • Remove the screw at the top of the O-ring.
    • If mold is present, clean the screw with disinfectant.
  9. Sink O-Ring Replacement: passo 9, immagine 1 di 1
    • Using an adjustable wrench, remove the O-ring.
  10. Sink O-Ring Replacement: passo 10, immagine 1 di 1
    • Replace the old O-ring with the new one.
  11. Sink O-Ring Replacement: passo 11, immagine 1 di 1
    • Re-assemble the sink, reversing all steps used to disassemble the sink.
    • Congratulations! Once all the steps have been reversed and completed, feel free to test out your updated sink.
Linea Traguardo
Brooke Don
Membro da: 11/05/24
193 Reputazione
1 Guida realizzata
UC Davis, Team 2-8, Vidal-Chiesa Fall 2024 Membro di UC Davis, Team 2-8, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S2G8
2 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 84
