Salta al contenuto principale
Singing Machine Shine Duets LED Lights Replacement
Cosa ti serve
  1. Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: passo 1, immagine 1 di 3 Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: passo 1, immagine 2 di 3 Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: passo 1, immagine 3 di 3
    • Remove the 10 mm screws on either side of the machine using a Phillips #1 screwdriver.
  2. Singing Machine Shine Duets LED Lights Replacement: passo 2, immagine 1 di 3 Singing Machine Shine Duets LED Lights Replacement: passo 2, immagine 2 di 3 Singing Machine Shine Duets LED Lights Replacement: passo 2, immagine 3 di 3
    • Remove the three 8 mm screws with a Phillips #0 screwdriver.
  3. Singing Machine Shine Duets LED Lights Replacement: passo 3, immagine 1 di 3 Singing Machine Shine Duets LED Lights Replacement: passo 3, immagine 2 di 3 Singing Machine Shine Duets LED Lights Replacement: passo 3, immagine 3 di 3
    • Use the opening tool or your hands to carefully pry open the now-loosened top panel.
    • The top portion of the shell is open, and the inside of the device is now accessible.
  4. Singing Machine Shine Duets LED Lights Replacement, LED Lights: passo 4, immagine 1 di 3 Singing Machine Shine Duets LED Lights Replacement, LED Lights: passo 4, immagine 2 di 3 Singing Machine Shine Duets LED Lights Replacement, LED Lights: passo 4, immagine 3 di 3
    • Remove the 10 mm screw from the LED lightboard using a Phillips #0 screwdriver.
  5. Singing Machine Shine Duets LED Lights Replacement: passo 5, immagine 1 di 3 Singing Machine Shine Duets LED Lights Replacement: passo 5, immagine 2 di 3 Singing Machine Shine Duets LED Lights Replacement: passo 5, immagine 3 di 3
    • Carefully remove the lightboard from the device, taking care not to damage any pins.
    • To reassemble, connect the pins on the lightboard to the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 68
