Salta al contenuto principale
Signode BXT3-16 Strapping Combo Tool Spring Replacement
Cosa ti serve
  1. Signode BXT3-16 Strapping Combo Tool Spring Replacement, Spring: passo 1, immagine 1 di 1
    • Before dismantling the strapping gun, ensure the power source / battery is removed.
  2. Signode BXT3-16 Strapping Combo Tool Spring Replacement: passo 2, immagine 1 di 1
    • Turn the strapping gun upside down.
    • Place it on a flat surface to keep the strapping gun stable during repair.
    • There are four Torx T4 screws on the bottom of the tool.
  3. Signode BXT3-16 Strapping Combo Tool Spring Replacement: passo 3, immagine 1 di 3 Signode BXT3-16 Strapping Combo Tool Spring Replacement: passo 3, immagine 2 di 3 Signode BXT3-16 Strapping Combo Tool Spring Replacement: passo 3, immagine 3 di 3
    • Use the Torx T4 screwdriver to remove the four 25 mm screws from the base plate.
    • Remove the single 25 mm Torx T4 screw from the front side of the strapping gun.
    • Use a Torx T4 screwdriver to remove the two 25 mm screws on the front of the tool.
  4. Signode BXT3-16 Strapping Combo Tool Spring Replacement: passo 4, immagine 1 di 1
    • Rotate the strapping gun to the opposite side.
    • Use the Torx T4 screwdriver to remove the remaining 25 mm screws from the front of the strapping gun.
  5. Signode BXT3-16 Strapping Combo Tool Spring Replacement: passo 5, immagine 1 di 2 Signode BXT3-16 Strapping Combo Tool Spring Replacement: passo 5, immagine 2 di 2
    • Rotate the strapping tool to the original position, with the model number and name facing you.
    • Firmly pull the guard plate and the tool apart using both hands.
  6. Signode BXT3-16 Strapping Combo Tool Spring Replacement: passo 6, immagine 1 di 2 Signode BXT3-16 Strapping Combo Tool Spring Replacement: passo 6, immagine 2 di 2
    • Use a metal spudger to lift the cutter.
    • Gently, push the spring out from the bottom of the base of the strapping gun.
  7. Signode BXT3-16 Strapping Combo Tool Spring Replacement: passo 7, immagine 1 di 3 Signode BXT3-16 Strapping Combo Tool Spring Replacement: passo 7, immagine 2 di 3 Signode BXT3-16 Strapping Combo Tool Spring Replacement: passo 7, immagine 3 di 3
    • Rotate the machine to remove the spring gently by hand.
    • Remove the spring from the base of the strapping tool.
    • Replace with new spring by inserting it the same way it was removed.
Conclusione
Altre 3 persone hanno completato questa guida.
Jainam Shah
Membro da: 02/01/24
172 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 46
Tutti i Tempi: 842
