Salta al contenuto principale
Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement
Attrezzature medicali
Né iFixit né questa guida di riparazione sono approvati dal produttore del dispositivo medicale o affiliati ad esso.
Cosa ti serve
  1. Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement, Filter for Gas Modules: passo 1, immagine 1 di 1
    • When performing this maintenance, a 'Maintenance kit, 5,000 hours' should be used
    • Remove the inspiratory section cover
    • Loosen the screw (1)
    • Lift off the gas module bracket (2)
    • Service Manual 4 - 14
  2. Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement: passo 2, immagine 1 di 1
    • Pull out and lift off both gas modules.
  3. Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement: passo 3, immagine 1 di 1
    • Note 1: When assembling, make sure that the connector muff properly seals around the inspiratory pipe (1). The connector muff must not be pushed too far onto the nozzle units (2)
    • Note 2: The gas modules used in Servo-i are factory adjusted for this purpose. When replacing gas modules, make sure to use only Servo-i gas modules.Similar gas modules intended for the SV 300/300A or KION / KION-i Systems must not be used.
  4. Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement: passo 4, immagine 1 di 1
    • Replace filters in the gas modules. When replacing filter, move the rubber seal from the old to the new filter.
    • Service Manual 7 - 3
  5. Siemens-Maquet Servo-i Inspiratory Pressure Transducer Filter Replacement, Pressure Transducer Filter: passo 5, immagine 1 di 1
    • Replace plastic nozzle units in the gas modules.
    • After replacement of plastic nozzle units, wait 10 minutes before connecting pressure to the gas modules
    • Service Manual 7 - 4
Conclusione
Maria Brown
Membro da: 05/04/20
196 Reputazione
2 Guide realizzate
Cal Poly, Team S1-G2, Zimmerman Spring 2020 Membro di Cal Poly, Team S1-G2, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G2
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 22
Tutti i Tempi: 482
