Salta al contenuto principale
Siemens Surpresso Compact drainage valve replacement
Cosa ti serve
  1. Siemens Surpresso Compact drainage valve replacement, Opening the Siemens Surpresso Compact: passo 1, immagine 1 di 1
    • Unplug your coffee maker!
    • Remove the water container, the brew group and the drip tray with pomace container.
    • Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
    • Depending on the model, additional sensors with cables may be installed on the top and side panels. You have to remove these before you can completely remove the housing parts.
  2. Siemens Surpresso Compact drainage valve replacement: passo 2, immagine 1 di 1
    • Remove the two Torx T10 screws on the top.
  3. Siemens Surpresso Compact drainage valve replacement: passo 3, immagine 1 di 2 Siemens Surpresso Compact drainage valve replacement: passo 3, immagine 2 di 2
    • Remove seven T10 Torx screws on the back.
    • The two screws at the bottom of the front can remain.
  4. Siemens Surpresso Compact drainage valve replacement: passo 4, immagine 1 di 2 Siemens Surpresso Compact drainage valve replacement: passo 4, immagine 2 di 2
    • Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
    • Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
    • Lift the top off.
    • On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
  5. Siemens Surpresso Compact drainage valve replacement: passo 5, immagine 1 di 2 Siemens Surpresso Compact drainage valve replacement: passo 5, immagine 2 di 2
    • Slide the side section of the brewing unit about 2 cm to the rear. This sometimes gets stuck and may require some force to remove.
    • Remove the two tabs from the power switch.
    • Take off the side panel with the brew group.
  6. Siemens Surpresso Compact drainage valve replacement: passo 6, immagine 1 di 1
    • Do the same with the panel on the other side.
    • To remove the water tank hose simply pull it of the pump.
    • Remove the side panel.
  7. Siemens Surpresso Compact drainage valve replacement, Gear Drive: passo 7, immagine 1 di 3 Siemens Surpresso Compact drainage valve replacement, Gear Drive: passo 7, immagine 2 di 3 Siemens Surpresso Compact drainage valve replacement, Gear Drive: passo 7, immagine 3 di 3
    • Rotate clockwise the expansion box about 60 degrees and pull it out.
    • The expansion box is frequently filled with coffee oils or grounds. Clean it from time to time. It can easily be separated into two halves.
  8. Siemens Surpresso Compact drainage valve replacement: passo 8, immagine 1 di 1
    • The drainage valve is directly plugged to the gear drive. The drive is fixed with five Torx T10 screws on the center panel behind the brew group.
    • Remove the five Torx T10 screws holding the gear drive in place.
  9. Siemens Surpresso Compact drainage valve replacement: passo 9, immagine 1 di 2 Siemens Surpresso Compact drainage valve replacement: passo 9, immagine 2 di 2
    • Push the gear drive outwards to the left. Pay attention, several cables might get caught.
    • Lay the gear drive on its side. Loosen the upper water connector by pulling the clamp and than sliding off the hose. Mind the O-ring on the end of the hose, replace it if necessary.
  10. Siemens Surpresso Compact drainage valve replacement, Drainage Valve: passo 10, immagine 1 di 3 Siemens Surpresso Compact drainage valve replacement, Drainage Valve: passo 10, immagine 2 di 3 Siemens Surpresso Compact drainage valve replacement, Drainage Valve: passo 10, immagine 3 di 3
    • The drainage valve is exposed.
    • Remove the spring on the lower end of the valve.
    • Lift the upper gray part of the valve. Push the lower part of the valve a little bit downwards und lift it out.
Conclusione
To reassemble your device, follow the steps in reverse order.
Altre 4 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
de en
100%
VauWeh ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
VauWeh
Membro da: 10/19/15
166.201 Reputazione
212 Guide realizzate
4 Commenti
Hi, will be a issue if i will cancel the valve by removing the cam and setting up the position as water will go straight away to brew?
Andrei Ciornei - Replica
Do I understand it right: you want to use the surpresso without a drainage valve? I think it's impossible. Swap it, it's rather cheap.
VauWeh -
Hat sehr gut geklappt! Hatte kurz Streit mit der Brühgruppe, aber ich habe dann gewonnen. Danke, sehr hilfreiche Anleitung. Manchmal muss man sich bloß trauen...
sabine.gorski - Replica
Freut mich. Genau dafür ist iFixit da.
VauWeh -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 91
Tutti i Tempi: 4,823
