Salta al contenuto principale
Siemens A56 Front Plate Replacement
Cosa ti serve
  1. Siemens A56 Front Plate Replacement, Battery: passo 1, immagine 1 di 1
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Siemens A56 Front Plate Replacement: passo 2, immagine 1 di 1
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
  3. Siemens A56 Front Plate Replacement, Front Plate: passo 3, immagine 1 di 3 Siemens A56 Front Plate Replacement, Front Plate: passo 3, immagine 2 di 3 Siemens A56 Front Plate Replacement, Front Plate: passo 3, immagine 3 di 3
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
Conclusione
Lauren Young
Membro da: 03/26/14
322 Reputazione
3 Guide realizzate
Clemson, Team 6-6, Benson Spring 2014 Membro di Clemson, Team 6-6, Benson Spring 2014
CLEM-BENSON-S14S6G6
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 169
