Salta al contenuto principale
Side Removal
Cosa ti serve
  1. Side Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: passo 1, immagine 1 di 1
    • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
  2. Side Removal: passo 2, immagine 1 di 1
    • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
    • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
  3. Side Removal: passo 3, immagine 1 di 3 Side Removal: passo 3, immagine 2 di 3 Side Removal: passo 3, immagine 3 di 3
    • Grab the top shell of the mouse and lift up to remove.
  4. Side Removal: passo 4, immagine 1 di 1
    • The capacitors on this board can release stored electrical energy if touched.
    • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
  5. Side Removal: passo 5, immagine 1 di 2 Side Removal: passo 5, immagine 2 di 2
    • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
  6. Side Removal, Side Panels: passo 6, immagine 1 di 2 Side Removal, Side Panels: passo 6, immagine 2 di 2
    • Locate the 5 mm silver flat head mounting screws (2) to the left and right of the scroll wheel and remove with the Phillips #1 screwdriver.
  7. Side Removal: passo 7, immagine 1 di 2 Side Removal: passo 7, immagine 2 di 2
    • Locate the snaps on the bottom corners of the mouse side panels and pop the indicated snaps out, using a spudger or your fingernail.
  8. Side Removal: passo 8, immagine 1 di 3 Side Removal: passo 8, immagine 2 di 3 Side Removal: passo 8, immagine 3 di 3
    • Repeat Step 6 for the opposite side panel in order to detach both sides from the base of the mouse.
  9. Side Removal: passo 9, immagine 1 di 2 Side Removal: passo 9, immagine 2 di 2
    • Grab the sides of the mouse and lift them up to detach from the base of the mouse.
Conclusione
royceeklund
Membro da: 01/18/13
79 Reputazione
3 Guide realizzate
Cal Poly, Team 18-36, Regan Winter 2013 Membro di Cal Poly, Team 18-36, Regan Winter 2013
CPSU-REGAN-W13S18G36
3 Membri
30 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,697
