Salta al contenuto principale
Side Panel Removal
Cosa ti serve
  1. Side Panel Removal, Side Panel Removal: passo 1, immagine 1 di 3 Side Panel Removal, Side Panel Removal: passo 1, immagine 2 di 3 Side Panel Removal, Side Panel Removal: passo 1, immagine 3 di 3
    • Before you start make sure that all of the leads have been disconnected from the computer.
    • It is strongly recomended to wait at least 15 minutes after turning it off to allow the computer and internal components to cool down.
    • It is recomended to lay the computer down with the pull tab at the top to allow it to be easily opened.
    • It is also worth mentioning at this point that for complete safety when working inside the computer that wearing an anti-static band and touching a grounded metal object before starting is good practice.
  2. Side Panel Removal: passo 2, immagine 1 di 3 Side Panel Removal: passo 2, immagine 2 di 3 Side Panel Removal: passo 2, immagine 3 di 3
    • In order to remove the side panel a single screw needs to first be removed.
    • The side panel can then be pulled towards the back of the computer using the pull tab provided.
    • The panel then needs to be rotated as showen in order to remove it from the computer.
Conclusione
Altre 5 persone hanno completato questa guida.
Oli
Membro da: 01/03/14
1.310 Reputazione
4 Guide realizzate
Un commento
I took it out, but now it’s not going all the way in
Ali - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 48
Tutti i Tempi: 2,189
