Salta al contenuto principale
Shure SM58 XLR Microphone Connector Installation Replacement
Cosa ti serve
  1. Shure SM58 XLR Microphone Connector Installation Replacement, XLR Microphone Connector Installation: passo 1, immagine 1 di 1
    • Holding the microphone connector in one hand and the microphone base in the other, line up the screw in the connector with the hole in the middle of the microphone.
    • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
  2. Shure SM58 XLR Microphone Connector Installation Replacement: passo 2, immagine 1 di 1
    • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
    • Do not push the microphone past this point or the connector may become stuck.
  3. Shure SM58 XLR Microphone Connector Installation Replacement: passo 3, immagine 1 di 1
    • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
Conclusione
After installing the connector back into the microphone, it should be ready to connect to any XLR cable.
Altre 4 persone hanno completato questa guida.
Ronald Lam
Membro da: 09/27/12
307 Reputazione
1 Guida realizzata
Cal Poly, Team 7-53, Forte Fall 2012 Membro di Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Membri
20 Guide realizzate
7 Commenti
Hi. I have followed the steps to #3. “Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight. “ However, the connector does not stay in place. It is still loose where the connector moves inside the microphone. I cannot get it to sit tight .
Joe Lee - Replica
Hi. I followed up to step #3. However, the connector does not stay tight. It keeps on moving inside with a little push.
Joe Lee - Replica
Hi. I followed up to step #3. But, the connect is still loose… Moves inside the microphone.
Joe Lee - Replica
Are the threads on your screw stripped?
Daniel Berger - Replica
Hi I have lost the screw in the side of the mic. Can you tell me the size of a replacement or where I can get one. Thank you
Chris Hall - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 10,526
