Salta al contenuto principale
Introduzione
The faceplate connects all of the internal wiring of the microphone. If it is defective (or wires need to be reattached to it), this guide shows how to replace it.
Parti
Nessuna parte specificata.
  1. Remove the yellow and green wires from the face plate.
    • Remove the yellow and green wires from the face plate.
    • Note which side the yellow and green wires connect to.
  2. Never open the microphone capsule. Attempting to open the capsule will likely result in permanent damage and make the microphone unusable. Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
    • Never open the microphone capsule. Attempting to open the capsule will likely result in permanent damage and make the microphone unusable.
    • Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
  3. Slide the face plate over the connector. Slide the face plate over the connector.
    • Slide the face plate over the connector.
Conclusione
Follow the steps of the guide in reverse to reassemble the microphone. In order to solder wires back to faceplate use soldering guide.
nat coll
Membro da: 27/09/2012
536 Reputazione
14 Guide realizzate
Cal Poly, Team 7-53, Forte Fall 2012 Membro di Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Membri
18 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 7,591
