Salta al contenuto principale
ShowerDoorDirect Shower Speaker Motherboard Replacement
Cosa ti serve
  1. ShowerDoorDirect Shower Speaker Motherboard Replacement, Battery: passo 1, immagine 1 di 2 ShowerDoorDirect Shower Speaker Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the suction pad by pulling the suction out of the slot that it is in.
  2. ShowerDoorDirect Shower Speaker Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the four 9.09mm Philips #1 screws that hold the 2 pieces of the cover together.
    • Pull apart the two halves.
  3. ShowerDoorDirect Shower Speaker Motherboard Replacement: passo 3, immagine 1 di 1
    • Hold the base and pull up on the battery.
  4. ShowerDoorDirect Shower Speaker Motherboard Replacement: passo 4, immagine 1 di 3 ShowerDoorDirect Shower Speaker Motherboard Replacement: passo 4, immagine 2 di 3 ShowerDoorDirect Shower Speaker Motherboard Replacement: passo 4, immagine 3 di 3
    • Remove the four 5mm Phillips #1 screws from the motherboard.
    • Desolder the two wires connecting the battery tp the motherboard.
  5. ShowerDoorDirect Shower Speaker Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Desolder the four remaining wires that are connected to the motherboard.
Conclusione
Matthew Dunkle
Membro da: 05/21/18
203 Reputazione
2 Guide realizzate
IUPUI, Team S1-G1, Harley Spring 2018 Membro di IUPUI, Team S1-G1, Harley Spring 2018
IUPUI-HARLEY-S18S1G1
7 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 341
